Performance after injector installation
Old Nov 7, 2002 | 06:26 AM
Shovelhead's Avatar
Administrator / Scooter Bum
Re:Performance after injector installation
If you think your tranny can take it ........Hook up the pump wire. ;D ;D
Old Nov 7, 2002 | 08:00 AM
Push Rod's Avatar
From: Drive till ya hit a Polar Bear, then go back 50 miles
[quote author=Ascraeus link=board=7;threadid=6716;start=0#63263 date=1036643418]<br>Also, my boost seems to have gone up. It seems like there's more boost at different levels of acceleration. At WOT, I'm pegging the 35 psi Autometer gauge. Also, there seems to be a lot more kick in 4th and 5th gear, more but not as much in 3rd or 6th. Would the injectors affect all of these things, in this way? I didn't expect more boost, and I thought the power curve would be affected more uniformly. <br><br>Can a stock HX35 turbo take 30-35 psi boost? <br>[/quote]<br><br>I'm a little surprised that you're getting 35 PSI in just EZ mode, but its not going to hurt your 35. I know a quite a few guys that take their stock 35s to 42/44 PSI and they seem to handle it. I think I'd want to stop at 40 PSI, though.<br><br>As for the differences you're feeling, its probably the gears. For example, in 3rd gear, your boost probably isn't getting up as you're running out of gear and up against the governor. 4th and 5th, you're pulling the gears hard, and it feels a big sluggish in 6th (in comparison to 4 and 5) because you're geared up higher.<br><br>Rod
Old Nov 7, 2002 | 10:52 AM
BigBlue's Avatar
I could see why you are getting more boost. You are getting more fuel. More fuel, more air, more boost needed. Or somethign like that. I know with the comp off, I get 20 psi, on, 28psi. I've pushed my HY35 to 35 psi in EZ mode all the time. Hit 40 for a sec. Seems fine to me. Our engines love having a load put on em. You may not have enough of a load on the engine in 3rd gear to really feel it.
rstl99
Jun 8, 2012 06:29 PM
MDMIKE
57
Jun 4, 2010 09:49 AM
Diesel fitter
Jul 5, 2009 09:41 PM
DieselGuyMike
15
Nov 30, 2007 08:40 PM
