Painting A Pillar Covers to Match My Truck
Old Feb 24, 2004 | 07:37 PM
AggiePhil's Avatar
I'm looking to buy a set of A Pillar Covers with the tweeter spots (for the Infinity system) and put my own tweeters in there. I found a set of them in Charcol, but my truck interior is Tan. I'm wondering if these could be spray painted to exactly match the color of my current pillar covers using some paint I get from the dealership, or if this would only look *ALMOST* perfect. I ask because since the pillar covers are textured, I'm not sure how painted ones would look. And if they couldn't be cheaply painted to look EXACTLY like they came that way, I might as well just keep looking until I find tan ones (which might take a while). How is this done?
Old Feb 24, 2004 | 08:03 PM
SmokinDodge12V's Avatar
Any aftermarket pillars Ive seen have to be painted to match exactly, you can go to your dealer and get matching paint in a small spray can and just be sure to clean them off with soap before you paint them and they should look just like the stock ones.
Old Feb 24, 2004 | 08:22 PM
AggiePhil's Avatar
So you don't think the fact that the pillar covers are textured will matter? I ask because I seem to remember hearing that some interior automotive paint has to be applied in a certain way that actually ADDS this texturing (as opposed to the texturing being molded into the plastic), and I wasn't sure if that would be a problem. Also, I'm not sure if this exact color of paint is still available since my truck is a 2001.
Old Feb 24, 2004 | 09:06 PM
Stamey's Avatar
I don't know about the dealer, but an auto paint store can mix you up some. I went the auto paint store, for about 60 bucks, and had my Dad shoot it, for free. He's a nice guy that way. In some cases the paint store can make up a spray can of custom mix, but I don't know if they still do that.
The dealer route sounds like a better choice if it's available.
Chris
Old Feb 24, 2004 | 09:15 PM
jigdog's Avatar
stat when i had my gauges put in the guys who did it painted the triple pod to match my charcol factory color ,they said it was speical kinda paint to stick to the plastic.it turned out great and looks factory.i will try to gets some pics,it has the speaker spot in it. are you putting in gauges at the same time?
Old Feb 24, 2004 | 09:57 PM
AggiePhil's Avatar
No, I'm not...although DodgeDiesel4x4 wants me to. LOL. Basically, I'm looking to put all the money I'm saving up into the sound system and gauges would take away from that. I'd like to hear more about the paint if anybody knows anything.
Old Feb 24, 2004 | 10:08 PM
vtailflyer's Avatar
I bought my paint from the local dodge dealer for about 5 bucks a can. It matched quite well (mist grey interior)
I painted the first coat with some white krylon "fusion" plastic paint, then painted the interior paint. worked well so far.
Cheers
Old Feb 24, 2004 | 11:41 PM
magnum's Avatar
The dealer spray looks like the best bet.
To paint plastic, it will adhere just like any other paint, if you stop and think about it, you have plastic everywhere on vehicles now days.
The MAJOR difference is in the prep, which plastic requires a bit more care. Don't use lacquer thinner or mineral spirits to clean. Use hot soapy water initially, scuff the surface with a "scotch brite" pad or something similar. Sandpaper will not get into all of the textured surface, and will smooth out the texture you have.
After scuffing, you should have NO shiny spots visible. Clean again with hot/soapy water, dry thoroughly, and just prior to painting, clean with isopropyl (rubbing) alcohol or a plastic prep cleaner. The last item is especially important if substances like "armor all" or high silicone shiny stuff has been used on the part.
You are ready to paint!
Old Feb 25, 2004 | 01:23 AM
kyle@ftlb's Avatar
Muted User
Where i work we paint the pods to mach the interior and for the dark interior we use Mopar "Agate" spray paint... matchs good. They have the tan color too. I can't think of the exact name of it off hand
Old Feb 25, 2004 | 10:47 AM
dodgediesel4x4's Avatar
I think the tan color is called "camel" but not 100% sure. When I get my pillar in soon (hopefully today, maybe) I'm gonna head to the dealer to get my agate can. I'll ask what the color is you are looking for.
(Just suck it up and get those DAAAAAAAAAARN gauges!!!!!!!)
P.S.........Chicken thurs nite, dont forget.
Hunter
Old Feb 25, 2004 | 06:15 PM
jigdog's Avatar
stat: thats good advice you will feel better about cruisin with your new tunes and what another 500.00 bucks.
Old Feb 25, 2004 | 06:23 PM
AggiePhil's Avatar
$500??? Is that what the gauge pod setup complete with gauges costs??? Dang! I'm going to need as much money as possible for the sound system I'm looking to put in. I mean, it'll probably cost well over $1,500 once I get everything put in. And that's just a super rough guesstimate.
Oh, I called the Dodge dealership today and a parts guy said that I could get the trim paint they sell, but recommended I go to a CarQuest Paint Store in town to get paint that's better matched. And cheaper too. He said that it's special interior trim paint that's super thin and will require 5-6 very light coats to totally cover up the underlying plastic. Said to wait 10-15 minutes between coats and to make the coats really thin. Now I just gotta get those pillar covers...
Old Feb 25, 2004 | 06:32 PM
jigdog's Avatar
stat ,if you go through peirs diesel @piersdieselresearch.com they can sell you gauges and the pod and they will dicker with you. that price i gave you included prof install to. $250 for pod and autometer gauges. they look cool.
Somebody show him a picture
Old Feb 25, 2004 | 06:39 PM
Stat try www.egauges.com I just got mine from there I got the Auto Meter Ultra lights egt and boost gauge with the full daul pod for 212.00 to my door.
Old Feb 25, 2004 | 06:59 PM
AggiePhil's Avatar
You guys should be in sales! I don't want the GD gauges! LOL. OR the extended warranty!
