Over boost
Old Oct 21, 2005 | 12:06 PM
Gotlift01's Avatar
Originally Posted by rjohnson
Just to be sure we're all on the same page...
The boost fooler will allow you to run with more boost, IF you have the power to generate it. The Boost elbow will close off the wastegate so no air gets to it, thus giving you max boost your power set up can generate.
With a good EZ, I think you would generate more boost than stock, at heavy throttle....but you need to install the elbow to get it.
Sorry if I'm restating the obvious. Your above statement sounds like there may be some misunderstanding on where the added boost comes from!
Good Luck
RJ
Sorry RJ, I worded that wrong...........it does allow for more boost but not if the wastegate restricts it.........that sounds better!!! Which is where the boost elbow comes in ( unless you have a hardline piece of crap like mine )
~Nick
Old Oct 21, 2005 | 12:15 PM
RowJ's Avatar
Nick,
I understood what you said...I was refering to Farmer Daves quote.
RJ
Old Oct 21, 2005 | 12:20 PM
Gotlift01's Avatar
AHHHH gotcha!!! Still I worded that a little bass ackwards............need more ( well mountain dew that is )
~Nick
Old Oct 21, 2005 | 12:21 PM
farmer dave's Avatar
I know that you get the moore boost from the box and that the boost fooler is only used to control the waste gate from opening. My question was is that fact that I don't have a boost fooler could that be causing the over boost codes?
Old Oct 21, 2005 | 12:25 PM
Gotlift01's Avatar
No the boost fooler doesn't have any control over the wastegate........the fooler is electrical and the wastegate in mechanical. That's what the elbow is for is to control the wastegates operation.
And you do have a boost fooler, it's built into the EZ box already..........it just sounds like it's not working properly!!! Therefore causing the codes
~Nick
Old Oct 21, 2005 | 12:37 PM
RowJ's Avatar
.... that the boost fooler is only used to control the waste gate from opening.
If you meant to type Elbow, instead of "boost fooler"...then your right.
And yes, defective Boost fooler would allow codes to show up.
RJ
Old Oct 21, 2005 | 12:42 PM
Sorry, that is what I meant to type. By "defective boost fooler", you are refering to the box, right?
Old Oct 21, 2005 | 12:44 PM
Gotlift01's Avatar
Sorry, that is what I meant to type. What do you mean by "defective boost fooler", are you refering to the box?
Yeah, the boost fooler in the box could be not functioning correctly and causing your codes to pop up...........you can send it back to EDGE and they can take a peek for you to see if that's the problem
~Nick
Old Oct 21, 2005 | 12:46 PM
I have a Van Aken box instead of an EZ. Will they also look at it and send a new one if there is something wrong with it?
Old Oct 21, 2005 | 12:57 PM
Gotlift01's Avatar
OHHH my bad, I thought you had the EDGE EZ.......sorry bout' that!!!
Umm I don't think that they will, dang product names!!
Where did you get your Van Aken from?
~Nick
Old Oct 21, 2005 | 01:08 PM
I actually bought it from another person. So I am not sure what it going to happen. Maybe I will have to get something bigger now because mine busted That would be a bloody shame
Old Oct 21, 2005 | 01:24 PM
Gotlift01's Avatar
Man I HATE it when that happens.............. I swear my single turbo broke, so I'm gonna get twins now just to be safe.........that way if one fails I have a backup!!!
I know the Edge w/ the juice monitor is supposed to be out around Christmas, that is if you want to pay almost 9 bills for it
~Nick
Old Oct 21, 2005 | 01:43 PM
Na, I am alright. I already have the gauges so there is 300 saved. I am not sure what I would do, but it would be a good excuse Maybe I will just get another fueling box if I can't get it fixed, and sneak a set of sticks in at the same time My wife won't notice the difference, until I hit the throttle then and and and finally
Old Oct 21, 2005 | 01:54 PM
Gotlift01's Avatar
Yeah I hear ya there, no need to waste money on what you already got!!
Some bigger sticks would be cool, I won't tell your wife if you don't
~Nick
Old Oct 21, 2005 | 02:45 PM
She will know when she looks at the check book. She will be ****** at me because she said no more mods until she gets another vechile. I don't know if I can drive my truck without a chip anymore. It is just so nice to have that boost and power.
