OK any ideas,Outlook monitor shows low boost
I just hooked the adrenaline.I still have my analog boost pressure hooked up.When the analog shows 20psi the out look shows 7psi.Any Ideas.It seem to run really well.Just not sure why it showing so low.No CEL
You are trying to run the Adrenaline with a outlook monitor? If you meant the Pulse monitor, it has a adjustment on it to fine tune your boost readings, it may be turned down. Go under boost psi adjustments & try adjusting the sensitivity.
beaver76
Aug 7, 2007 09:01 PM
Smokeman
May 30, 2007 08:35 AM
Baranof
Apr 12, 2007 05:52 PM
beaver76
Mar 27, 2007 11:11 AM
dodgebowhunter
Dec 11, 2006 05:49 PM
