Boost on Outlook monitor???
Old Dec 9, 2006 | 03:59 PM
dodgebowhunter's Avatar
How does the outlook monitor pick up the amount of boost the turbo is putting out? Is this a correct reading or how accurate are the numbers it is putting out? Has anyone checked with a stand alone gauge and the outlook and compared them? Thanks ahead of time!
Old Dec 9, 2006 | 04:20 PM
Luvnacumns's Avatar
The boost on my outlook monitor was always higher than my analog guage.. If I remember right it was about 5-6 pound higher... I believe it gets its reading straight from the ECM...
Old Dec 9, 2006 | 05:33 PM
973604x4's Avatar
it gets its reading from the Map sensor....which with most aftermarket devices is being fooled somewhat...so no, the outlook isn't super accurate.
Its ok though, the Edge Attitude and A2 are the same way.
Old Dec 11, 2006 | 09:36 AM
Bud Kunz's Avatar
Boost fooler will not screw up the reading if it is plugged in right....should plug outlook into the stock sensor and then whatever box or fooler you have. this will make the outlook read correctly, but still send the "fooled" signal to the truck computer.
Old Dec 11, 2006 | 10:09 AM
SehrleBD's Avatar
^Thats what I was about to say.
Old Dec 11, 2006 | 05:49 PM
Thanks for the replys I'm gonna install the outlook this week!!
kyle_truck_pull
Mar 31, 2008 12:45 AM
beaver76
Aug 7, 2007 09:01 PM
Smokeman
May 30, 2007 08:35 AM
Baranof
Apr 12, 2007 05:52 PM
beaver76
Mar 27, 2007 11:11 AM
