boost question on outlook monitor???????
Old Mar 30, 2008 | 07:03 PM
kyle_truck_pull's Avatar
Exclamation boost question on outlook monitor???????
i have an outlook monitor and i just put on a 64mm turbo. with all my mods i thought i should see more boost. does the monitor only go to 32 pounds? this new turbo should build 70 easy. so i just wanted to know if the monitor wont go any higher than 32 or if anyone has seen more.
Old Mar 30, 2008 | 07:30 PM
homewrecker's Avatar
If the torque dog is doing pressure it is manipulating the map sensor signal which is causing the outlook to read low.I know my outlook never read right with the mp-8 installed.Try hooking the outlook map plug first then the torque dog.
Old Mar 30, 2008 | 08:39 PM
so the monitor will read more boost?
Old Mar 30, 2008 | 09:13 PM
Brian Lent's Avatar
I was told that the Outlook only reads 32. That is all mine would read. Now with the TST boost fooling it only goes to 16.
Old Mar 30, 2008 | 10:08 PM
jballou's Avatar
2 threads same basic question, delete one.
Old Mar 31, 2008 | 12:45 AM
CLeger67's Avatar
Check out my experience and go analog, you'll be glad you did.
https://www.dieseltruckresource.com/...d.php?t=186399
beaver76
Aug 7, 2007 09:01 PM
Smokeman
May 30, 2007 08:35 AM
Baranof
Apr 12, 2007 05:52 PM
beaver76
Mar 27, 2007 11:11 AM
dodgebowhunter
Dec 11, 2006 05:49 PM
