Not Good
Old Nov 7, 2002 | 07:02 AM
DarrellB's Avatar
Not Good
I think my Power Max took a dump on me. I was coming home form work this morning and the truck started to cut out and then when I looked down the green fuel light started to blink and then went out completely. I turned of the PM and truck ran fine. I didn't feel like looking at it this early so I'll have to check it out later today but I'm hoping it's just the pump wire unplugged or something like a loose conection.
Anyone else had the same problem with their Power Max?
Darrell
Old Nov 7, 2002 | 08:28 AM
PourinDiesel's Avatar
Re:Not Good
Darrell,<br>Sorry to hear of the difficulties.<br>I would call Mark Chapple, and make sure that he takes care of you, and replaces this unit.<br>Unfortunately I have heard of alot of people having problems of stumbling and stuttering with the Power Max units.<br><br>Give me a call or email if you need anything.<br><br>--Justin<br>
Old Nov 7, 2002 | 05:33 PM
DarrellB's Avatar
Re:Not Good
Thanks Justin,<br><br>I'm going out to take a look at it before I go to work. Still hoping it's just the scotch lock or a loose terminal conection. ???<br><br>Darrell
Old Nov 7, 2002 | 06:40 PM
DarrellB's Avatar
Re:Not Good
Well I'm still confused [undecided] [undecided]<br><br>Went out and did a little checking and took all the conections loose and put them back together with some dye electric grease. (good so far)<br><br>Put Briar's test gauge on and fuel preasure was good. Never could drag it below 7.5 psi for extended WOT runs. (still in good shape)<br><br>I couldn't get the truck to duplicate what it did this morning. Going to see what it does on the way to work and if it still stutters I'll have to call Mark at TST. <br><br>Darrell
Old Nov 8, 2002 | 09:09 PM
DarrellB's Avatar
Re:Not Good
Well it's running just fine now. [undecided] It must have been a loose connection on the fuel pump wire. : I ran the **** out of it this morining racing 5 PowerJokes up the cut and it did just fine. ;D<br><br>Darrell
vinny
Dec 6, 2010 09:11 PM
32tudor
Feb 1, 2010 09:19 PM
turbo hoss
Oct 21, 2007 02:19 PM
