Next 24V upgrade?
Old Sep 10, 2007 | 10:33 AM
wildchild97's Avatar
Next 24V upgrade?
Me and my dad are building a pulling truck/rare daily driver....So far we have been getting 3rd-5th place in all pulls we have been to....Here is what we have.... 2002 6speed dual wheel Flatbed Cummins, BD twins, Redline box stacked with an EZ, custom built 230hp injectors, ATS High Arc intake, Water/Meth, Hotrod vp44, and i think that is about it....in your opinion what would be the next upgrade? Thanks....
Old Sep 10, 2007 | 10:43 AM
dieselman43's Avatar
Bigger twins maybe????? You could always try new boxes. Maybe a TST Powermax 3, I know they stack good with an EZ. Maybe propane or nitro, depending on what class you are pulling in.
Old Sep 10, 2007 | 10:47 AM
dzlfarmboy's Avatar
What gear do you pull in and what kind of RPM are you turning going downt the track?
If you dont have it already
Heavy DD Clutch ( SouthBend )
Valve Springs so you can really use your Rpms (F-1 Sportsmans springs)
Possible cam if you already have that stuff.
Old Sep 10, 2007 | 11:15 AM
Ph4tty's Avatar
Ladder bars?
A97dodge4x4's Avatar
p-pump it. forget about the electronics. there is a guy around here that has p-pumped his truck and is still able to drive it down the road. thats if he wanted too.
Old Sep 10, 2007 | 12:12 PM
Already have ladder bar, bump stops, weight bar ext....... i didnt think you were supposed to stack anything with a redline other than i timing box? We usually pull low 4th I think we are going to try High 2nd, or low 5th on a drag sled.....
Old Sep 10, 2007 | 12:19 PM
I was saying stack the EZ with the Powermax, my buddy made good power with his 99 with those two stacked. Or you could p-pump it, I would try bigger twins though.
Old Sep 10, 2007 | 12:23 PM
dzlfarmboy's Avatar
He already has a Redline box why would he want to use a TST when he can turn 4k with a readline and Ez
Old Sep 10, 2007 | 12:24 PM
scottsjeeprolet's Avatar
SO VP44 pump?
I've heard the HRVP44's pumps limit you on fuel.
Old Sep 10, 2007 | 12:25 PM
Yea, that is true, I have never heard of a Redline box though. Where do you get that and what kind of specs do you get on it?
Old Sep 10, 2007 | 12:38 PM
CarcajouCummins's Avatar
Valve springs to get the benefit of the Redline. Other than that, you have alot of good stuff for making the power. I would address the driveline.
What gears? If you are running 3.54 gears, run second hi. If you have 4.1 gears, you might want to jump on up to 5 lo, but definately run 2 hi at least. Do you have the rear locked up? If not spend some money on a locker for the rear. A locker in the front would be a good idea as well.
Old Sep 10, 2007 | 12:44 PM
The redline is the bad boy, can't really upgrade when you own a redline. A Hot Rod VP will fuel fine, no need to get a SO. The Hot Rod is a big step up from the HO that was stock on his truck.
Old Sep 10, 2007 | 01:16 PM
dzlfarmboy's Avatar
http://www.bluechipdiesel.com/shoppingcart.html
Pretty much the end to all boxes for the 24v, will fuel to 4000rpms, must have upgraded valvesprings to do so, and it completely takes over the fueling from the ECM ***** to the walls. Would be the best box for a 24v sled puller with an EZ
Old Sep 10, 2007 | 01:26 PM
Thanks for the info dzlfarmboy, wonder if it would stack with the bd I have. I printed off the waiver form and I am considering that the hot comp might have to sit for a while if it is that good.
Old Sep 10, 2007 | 10:04 PM
I already have a Spool (or locker) in the rear end.....I running 3.55 gears.....New 265 Wrangler MTR's.....as well as a southbend Dual Disk..... ARP headtuds.....
