NEW From Quadzilla "The Ultimate Controller" Coming Soon to the DTR Performance Shop!
Old Jul 27, 2005 | 02:59 PM
Lary Ellis (Top)'s Avatar
Admin Team Leader
Looks like Quad has done it again! He finally gave me permission to tell you about his latest secret project. He has designed a new controller/monitor that works with his Xzillaraider series boxes (and others) with all the gauges you are ever going to need!
Here is a quick rundown of his new creation, it will be available right here soon!
Remember, you saw it first on DTR!
Retail around $399.00
Controller Features:
Stand Alone Operation
Will work on 95-06 Powerstrokes, 98-06 Cummins, 01-06 Duramax’s
Reads EGT, Boost, and Trans Temp with the option to read Fuel pressure (fuel pressure is an add on)
Analog LED Bar graph that is user definable green (9), yellow(4), red(3) (user definable for any reading and definable as to the color vs. temperature)
Graphic VFD, Vacuum Fluorescent Display
Won’t distort in Bright Light, Heat, or Cold Weather
2 Color Programmable warning lights
Photo sensor that will automatically dim or brighten display and LED bar graph based on light conditions
8 adjustable brightness settings on the display
Multiple user selectable warning screens to be displayed at user definable minimum or maximum readings
Displays 3 readings at once, plus power level
Multiple Display options including a variety of ways to display any 2 readings, or any single reading in a large format.
Recalls highest or lowest value of all readings, ex. Fuel pressure would be lowest number, EGT would be highest number
Built in multiple expansion ports
Simple installation, no wiring required, must tap exhaust manifold.
Controls Xzillaraider Modules and displays Power Levels
De-fuels based on any user defined max or min reading automatically and returns back to the power you set it on
Can be customized to de-fuel using and, or, <, >, = to, and can include any 2 readings
Controls most switchable Power Modules or Chips available ( may require adapter cable assembly) including, but not limited to:
Edge, Van Aaken, Bullydog, TS Performance, and BD Power
Also controls most 3, 4 & 6 position 7.3L chips.
De-fuels any of switchable module or chip based on user defined minimum or maximum readings and returns back to the power level you set it on
Displays power levels or % of power depending on the module.
Controls Multiple Power Modules Simultaneously.
Currently set up for 2, but 3 will be an option. Shows power level on both modules.
Adjust both modules on the fly.
De-fuels Multiple Modules based on user selectable options:
primary first, then secondary
Simultaneously
Alternating (ex. Primary then secondary, then primary, then secondary.)
Included base can be mounted in 2 1/16” gauge pod or configured to stand alone to be mounted in the location of your choice. Base rotates vertically and horizontally to match your mounting location.
Custom designed and molded enclosure with elastomer buttons (similar to a remote control) Backlit buttons
Competitively Priced.
Add-ons: May not be available upon initial release.
Fuel Pressure Sender and Harness
Real Time Data Monitoring
Read DTC codes and Erase DTC Codes
Turbo Timer
Gauge does have a maximum number of expansion ports so you cannot add every add-on and multiple modules at the same time, but there should be enough room to make everyone happy.
Old Jul 27, 2005 | 09:58 PM
BigBlue's Avatar
Now that's awesome.
Old Jul 27, 2005 | 10:18 PM
smokindog's Avatar
Does it control the TST? That things sounds amazing at $399!!!
Old Jul 28, 2005 | 12:13 AM
qzilla's Avatar
We are working on testing TST stuff. It has been really time consuming working with all the manufactures products. Most likely it will work with everything, but maybe not on the initial release.
We will be doing a lot of additional beta testing very soon.
Quad
Old Jul 29, 2005 | 05:37 PM
Admin Team Leader
New pictures of one of the prototypes in use. Man that's one clean looking display
Old Jul 29, 2005 | 05:46 PM
Marine's Avatar
Veteran: Marine Corp
Top,
don't you think your EGT's are a little high?
Mike
Old Jul 29, 2005 | 09:00 PM
Admin Team Leader
Originally posted by Marine
Top,
Mike
Not for 150 MPH
Not my truck, I just have some pictures Quad sent me so you guys could see what it looks like.
Old Jul 29, 2005 | 11:02 PM
DR3500's Avatar
the boost is REAL low too!
Old Aug 4, 2005 | 04:10 PM
qzilla's Avatar
Top,
Mike
Not for a 3rd gen!
We just set the gauge up to take pictures. The plastic in those pictures are for show and are too soft to remain in the heat. The prototypes are not nearly as pretty so we took some pictures of these so you guys can see what they look like. It is the best we can do until the molds are finished.
Quad
Lary Ellis (Top)
83
Dec 19, 2005 01:35 PM
PThree
22
Nov 30, 2004 06:13 PM
OT-OF-Here
Oct 12, 2004 08:11 AM
