new automatic tranny wont shift
Old Nov 23, 2006 | 05:13 PM
ky4wheeler's Avatar
i just got my rebuilt tranny back in my truck and now i only have park reverse neutral and first. it feels like it trys to shift when you let out of it for a second but then just goes back to first. checked all conectors. i reset the apps more than once. any help would be great im stuck with a truck with only first gear. you cant even manually shift it
Old Nov 23, 2006 | 05:51 PM
John Faughn's Avatar
Do you have the adjustment info for adjusting the TV cable to trans. ?
fluid level ,
You should go to the user control pannel and put in the info on your truck , it helps to help you .
Old Nov 23, 2006 | 06:01 PM
ky4wheeler's Avatar
its a 2001 no tv cable adjustment info
Old Nov 23, 2006 | 07:03 PM
RickCJ's Avatar
Are you sure?!? Hows it shift?
Old Nov 23, 2006 | 07:06 PM
ky4wheeler's Avatar
tryed the tv cable adjustment no help. anything else guys
Old Nov 23, 2006 | 10:43 PM
chop342's Avatar
From: Climax, MI (between battlecreek and kalamazoo)
i would guess that either the seal rings on the input shaft and front clutch drum are cut and leaking or you have a valve body issue.
Chris
Old Nov 24, 2006 | 01:54 AM
ky4wheeler's Avatar
tranny went together nice and smooth. no leaking from the tranny. it just wont shift. if you let out of it you can kind of feel it in second for a second but then it just like slips into neutral and then will kick its self back to first
Old Nov 24, 2006 | 11:23 AM
ky4wheeler's Avatar
replaced new govenor sensor and solenoid with now luck. ive dont everything i can think of and still nothing any help would be great guys
Old Nov 24, 2006 | 12:54 PM
Offshoreracer's Avatar
Replace your transmission speed sensor ( output shaft). It is located on the overdrive housing, large white sensor. Most likely it was damaged during your R & R, or the magnet on the end picked up to much sludge with the fluid change, and it can't read the rpm's. Most parts stores carry them. I just picked one up at Autozone today to put in a truck. Fixed the problem and takes 5 minutes to do. If the sensor can not read the rpm's the trans will not shift out of first gear. Be advised when you remove the old one fluid will run out.
Fred
Old Nov 24, 2006 | 01:53 PM
zfort001's Avatar
Park with the nose down when you replace the output shaft speed sensor and if you are quick you might loose a few drops of fluid. I had the same issue in my 2000 gasser changed out the sensor and good to go. Also check for codes to ensure the trany is talking to the ecm.
Old Nov 24, 2006 | 07:40 PM
ky4wheeler's Avatar
well lets see what i did today. new speed senor, new govenor solinoid, new govenor sensor, new computer and all leads to nothing. but i did find i had codes 1757 and code 0713 appear when i went on a long drive in first gear. i tested the wires and found i have 10.8 volts leading from the orange wire to the transmission when i should have 0 or under 5. this this throwing the trans temp voltage to high and the govenor sensor to high. i am at a loss guys and my other car is down and out
Old Nov 24, 2006 | 10:48 PM
chop342's Avatar
you have internal trans issues like cut seal rings on the input shaft into the front clutch drum or loose valve body, replacing solenoids and sensors will not fix the troubles. you have an internal hydraulic leak going on take it back to where it was rebuilt and tell them to fix it.
Chris
PM me with any ?'s you have and i will try to help with it.
Old Nov 25, 2006 | 03:25 PM
ky4wheeler's Avatar
what would be causing the internal leaking. everything in this tranny is new. my question is what is causing the transmisson temp voltage high code and the pressure volts to high code. what tells the computer what volts should be going to those sensors.
Old Nov 25, 2006 | 07:42 PM
chop342's Avatar
make sure the trans control plug on the drivers side of trans is plugged in all the way, its the plug next to the manual valve linkage. the plug on the side is the neutral saftey switch. the pcm sends reference voltage to the trans sensors and solenoids if it see's no voltage coming back the pcm is sets codes because sensors are out of threshold. so make sure the plug is in all the way and none of the pins are bent or corroded. also did the sensors and solenoids get replaced when the trans was rebuilt. if not i would make sure they are working if the trans is plugged in, also make sure they are plugged in inside the trans. Govenor pressure sensor and control solenoid have plugs inside trans. next, your internal leaks can be caused when the front clutch drum and pump are installed if the seal rings are not properly wrapped and installed they can be cut or nicked causing pressure leaks internally. also make sure the VB is tight.
PM me if you have any more issues and i will try to help.
Chris
Old Nov 25, 2006 | 08:29 PM
ky4wheeler's Avatar
trans is plugged in all the way. the 10.8 volts are coming from the computer on pin number 1 white connector. the organge wire
