Need some advice quick- head stud install
Old Aug 12, 2006 | 05:32 PM
cluckmaster's Avatar
In the process of installing my ARP head studs. Does the rocker stand/tower have to be machined down to clear the nut on the stud that goes directly down through the rocker assembly?
Old Aug 12, 2006 | 05:57 PM
Jetpilot's Avatar
No. The only thing you will need to do is take a dremel tool and grind a little out of the valvecover top to get a good seal on the gasket.
Doug Smith
Old Aug 12, 2006 | 06:48 PM
Dshiftff's Avatar
I machined mine down thats what the directions said to do in the new kit. Installed stud height off the block to the top of the stud shouldnt be more then 6.6 inches.
ARP now has a shorter stud for the tower so there is no more valve cover clearance problems.
Old Aug 12, 2006 | 07:19 PM
I do have the new shorter studs.
Jet Pilot- it looks like with the new shorter studs, there isn't going to be enough thread purchase in the nuts without machining. How much thread needs to be threaded in the nut? Thanks! -Josh
Old Aug 12, 2006 | 07:24 PM
Jetpilot's Avatar
I would be sure that the stud is even with the top on the nut......
Doug
lostcreek21
Mar 1, 2010 06:13 PM
goose2w1
Nov 18, 2008 01:43 PM
82NDSNPR
Jul 1, 2008 08:56 PM
74dart
Jul 7, 2007 07:58 PM
Megaramasaur
20
Mar 23, 2007 06:51 AM
