need some advice
Old Nov 7, 2010 | 08:55 AM
jkrauss's Avatar
need some advice
I have a stock 1998.5 24 valve 2500 2 wheel drive with a auto trans , 198000 miles, I want to add some after market equipment I need more power to pull my fifth wheel,The only new parts on my truck is air dog 100 fuel system and vp injection pump, I need some advice where to start adding aftermarket parts and where to buy them.
Old Nov 7, 2010 | 01:21 PM
baddodges's Avatar
i have a 98.5,i put bigger exhaust,and an edge ez chip,it pulls my 5th wheel and horse trailer great,as other things wear out i will replace them with after market parts ofcourse.
Old Nov 7, 2010 | 02:38 PM
Shovelhead's Avatar
Administrator / Scooter Bum
Where to buy?
Look at our on-line store: http://www.dodge-diesel.org/
It's how we keep the site free for our members.
Old Nov 7, 2010 | 05:24 PM
wurkenman's Avatar
Where to buy?
and you can't find them cheaper anywhere else.
Old Nov 7, 2010 | 07:46 PM
rebal's Avatar
smarty /RV275s and a better torque converter if its an auto and shop DTR if you can we dont want to pay for no stinkin site
Old Nov 7, 2010 | 08:05 PM
jkrauss's Avatar
Where to buy?
It's how we keep the site free to our members.
I did buy my air dog from this site I will purchace my new exhaustand air intake from dtr store but Im not sure which exhaust or intake to buy ,I also would like to install new injectors I did not see any for sell in the dtr store
what is a rv275s and what kind of torque converter ?
Old Nov 8, 2010 | 10:11 AM
Mike Holmen's Avatar
The Guru
How heavy is your trailer? You plan to tow in OD? I broke my 02 stock lock-up clutch (converter) at 6000miles towing my 12k RV, just using an ez. If you want abit more power RV275 will work.
The programers work, don't get me wrong but , just the stock transmission isn't that tuff. At that point it gets expensive in a hurry.
A valve body upgrade and aftermarket coverter would help out lots. Stay away from the low stall converter, so called towing converters.
Old Nov 8, 2010 | 06:54 PM
jkrauss's Avatar
my trailer is 11500 what is RV275 yes i would like to pull in overdive
Old Nov 9, 2010 | 02:08 AM
nasty01cummims's Avatar
Rv275's is a cummins injector typically found in cummins equiped motor homes? Correct me if I'm wrong but I think there +/- 40hp over stock. And a set could be had for around $400
Old Nov 9, 2010 | 06:23 PM
jkrauss's Avatar
Do I get these injectors from cummings ?
Old Nov 10, 2010 | 01:00 AM
You probably could get a set from CUMMINS. But, the chances of you over paying go up a considerable amount. Most aftermarket injector vendors carry them.And carry them a lot cheaper. Just do a google search. Or you could contact Larry Ellis(Top) and see if he could get you a set through the DTR store. Helps keep this forum free.
Old Nov 10, 2010 | 02:58 AM
wyododge's Avatar
Not sure what route your gonna take, but the first thing(s) I did was a 4" exhaust, FASS 150 LP, and a cold air intake. Made a noticeable difference. I ain't gonna win no races pulling a fifth wheel loaded with cows or hay, but I am not replacing my tires twice a year either. At this point if I had the extra dough, I might consider a smarty, but adding horsepower will put strain on other components. JMO
Oh ya and a full set of gauges (FP, EGT, BOOST) from the DTR store will give you a 30 - 50 HP increase. Someone here did a dyno test to confirm that, I think Lary has the info somewhere.
Old Nov 10, 2010 | 03:29 AM
Haha. I guess I'm still waitin on my isspros to give me that 30-50hp wyo.I heard a DTR sticker is good for around 10 hp. But like wyo said. Let her breath. Intake, and exhaust. But don't get caught up in the hype of the CAI that claim 30 hp and 60 foot pounds. I think there a dyno run on here somehwere that confirms that. A bahf is more wallet friendly and cost effective and can be purchased at most auto parts stores. And I'm still not sold on the "cold air" claims. I mean really, how cold is it after its spun through a turbo at tens of thousands of rpm. IMHO..that's why the good lord made intercoolers. And a simple 4 inch exhaust makes a big difference over the stock 3 inch system. Lower egt and some report quicker spool up. Just my .02 cents.
Old Nov 10, 2010 | 05:06 PM
Clunk's Avatar
Finally, real world ideas about pulling and keeping drivability...not big turbo/big injector/big exhaust heat/more big exhaust heat and general pain. Did I mention lots of big exhaust heat?
dodgemaniac
Competition / Pulls / OffRoad
Jul 31, 2008 10:15 AM
bsj04
Sep 20, 2007 08:09 AM
ryan466
Aug 30, 2006 10:10 AM
Apr 20, 2003 11:16 PM
