Need opinions on guages
Old Dec 29, 2003 | 06:46 PM
Cumminsdude's Avatar
Hey Jr. I got my steering wheel thing and I can set it on there and give you an idea but it won't be on for probably a couple days. I may get to it tomorrow but I can post a pic of it now if you'd like.
Old Dec 29, 2003 | 07:47 PM
stonewalldiesel's Avatar
Just my 2 cents, I mounted my Isspro's on the pillar 3 of them. Just a little advise. I started to cutup my original pillar to get every thing to fit wow what a mistake there is no need to do this. Just remove the original pillar and put in safe keeping just in case you sell it and want to keep the gauges. All i did was mount the new pillar using a nylon stand off spacer between the pillar and metal support and drilled a small hole in pillar and metal frame and mounted with a automotive self tapping screw. I dipped the screw in the same color paint as my new pillar. The rubber seal for the door frame helps to keep everthing place and mine has not moved at all . Looks Excellent!!! Also I put a piece of black rubber profile on the edge of pillar thats by the windshield for cosmetic purposes. I also mounted a Autometer Oil pressure gauge on my shift console between cup holder and shifter. Looks great also. I did have to modify the adjustable cup though. It doesn't adjust anymore!!!
Old Dec 30, 2003 | 10:07 AM
jrs_dodge_diesel's Avatar
I would like to see it whenever you get it installed Cumminsdude. I heard that the steering column mount blocks a few warning lights from being seen.
Haulin_in_Dixie
Jul 7, 2023 02:13 PM
lglamb
Aug 10, 2006 06:39 PM
yomitch
Nov 26, 2002 09:16 AM
Oct 8, 2002 06:52 AM
