need to know what im getting into??
Old Jan 13, 2007 | 01:46 PM
65fury's Avatar
okay i have some more questions, i already posted a thread about how much hp you guys thought i would make, but i was reading on the 600-650hp 12v thread and it brought more questions to mind. my mods when totally done with truck will be....
-laser cut dvs
-435 injectors
-custom twins(s400 and upgrade hx35 with 60mm compressor and 12cm wastegated turbine
-#4 fuel plate
-home made valet switch(not for performance)
-4k rpm kit with 60lb springs
-marine head gasket .10 over
-12mm studs
with those mods will my stock lift pump work and how much timing should i give it??
jason
Old Jan 13, 2007 | 03:51 PM
65fury's Avatar
come on guys i need to know before i go and put all these mods on my truck, please i need some answers. thanks
jason
Old Jan 13, 2007 | 06:09 PM
Muddin_dude06's Avatar
Welllll, IMO one thing I will say is for that setup you are going to need like a 16cm non-WG'd housing on the HX35 and a 38mm-ish external wastegate. And you will probably also need an O-ring or Firering setup as well.... .02
Old Jan 13, 2007 | 07:41 PM
65fury's Avatar
so the 12cm wastegated housing aint gonna cut it huh. well i have my 18cm housing from my 1990 engine, will that work?? and i didn't have a shop close by for the o-ring and i really need to get my truck running again so i didn't wait and i put the engine back together.
jason
Old Jan 13, 2007 | 09:05 PM
cluckmaster's Avatar
hey, man. I agree you may need to o-ring the head or at least go with a marine gasket and studs. i think even the marine gasket/head studs aren't reliable past something like 50 lbs. youre going to have to keep the timing set fairly low with the stock head gasket- probably 15 or 16. -josh
Old Jan 13, 2007 | 09:25 PM
65fury's Avatar
well i do have the marine head gasket and i did the studs so i guess i will play it safe with the twins, thanks
jason
TayTay
69
May 13, 2015 03:42 PM
tool
Sep 1, 2005 08:17 PM
JKM
Jul 3, 2005 04:59 PM
Matt400
Sep 28, 2003 09:55 PM
