need help with transmission?
Old Nov 11, 2007 | 08:13 PM
Destination's Avatar
im trying to decide if i need the billet input shaft when i git my tranny work done what do you guys think my hp numbers would be with a good turbo upgrade??
Old Nov 11, 2007 | 10:18 PM
anyone have a guess what my hp numbers would be right knoww????
Old Nov 11, 2007 | 10:27 PM
Bjans's Avatar
your between 3 and 400 id say! Yes go with at least a billet input shaft when you do the tranny, if not when you do break it, they will heve to pull the whole trans back out, where as if you break an output shaft, they will only have to pull off the t-case. Make sure you get a good one, not the cheapest you can find.
Old Nov 12, 2007 | 10:25 AM
timbeaux38's Avatar
You should be at about 4 bills currently. Go with the billet shaft for no other reason than if you bust a stocker, it may take out your TC and pump..... Most companies will not warranty the converter if you grenade a stock shaft.
If I were you I'd look really hard at a 64/14 from HT or II.. both would work well with your setup.
Old Nov 12, 2007 | 08:06 PM
ya that is next on the list cause egts git pretty toasty, i think this week im going to give Dave G. a call and see what else he might recomend
Old Nov 12, 2007 | 09:52 PM
Big Blue24's Avatar
I think you are putting 350 to the ground with your stock auto. Probably have 380 available with a good tranny, and probably 450 with a 62 series turbo.
Dauntless
15
Aug 30, 2016 08:37 PM
straightpipe
Mar 7, 2003 04:09 PM
