Need a couple more Beta testers with stock to mild trucks
We are officially beta testing our "new" version of the XZT for the 98-2 trucks. This box makes between 60-70 hp depending on your pump. It is extremely easy to install and DOES NOT tap the pump wire.
It is adjustable with a toggle switch from 0-timing only-60-70hp. The timing only setting is usually 20-30hp but, is not a big change, it is mostly for fuel economy and to cool egts.
The module does boost fooling even in the off position.
I already have a pretty long list that we are sending these out to but, I need a couple more to fill the test. We have a lot of people on the beta list and we are using them but, we are looking for either stock trucks or trucks with very mild modifications (small injectors, exhaust, intakes etc).
It would be great if I could get someone to compare it to an EZ, Puck or Smarty as well.
If you are interested in helping us with some feedback please shoot me a pm.
Some things we will want to know are:
Good horsepower gain?
Drivability
Fuel Mileage
egt
ease of installation
If I left anything out let me know. Also since I only need a couple please do not get upset if someone beats you to the punch. I would prefer at least 1 98-00 and 1 01-02. From there I will split it between tranny types.
Quad
Drivability
Fuel Mileage
egt
Quad
I would be happy to try one out. I have a new VP that has never been tapped and I am running my juice in EZ mode right now. I have a 2000 and also it has a fresh trans in it. PM me if I can help. Also I just installed the Jammer stage 2 nozzels.
This is a common questions and a very valid question, so I am going to do what I can to clear it up.
Beta testing is not free. I wished it was but, we have been burned pretty good in the past. While it is not free on the front end, it can be free if you want it to be.
The beta cost is DEEPLY discounted. We pay all shipping to you and from you as many times as it takes or if it is needed for one reason or another.
At ANY time you can get a full refund. Whether you don't like it, don't have time or whatever you can get all your money back. In the end you will end up with the very first production units and they will be up to the full production specs if you need it. You can run it, sell it, do whatever you want with it, or you can just flat out send it back and get your money. We just need the testers.
Also, I believe in this test the most important things will be fuel milage and power delivery. These two things are all I can see personally that might be changed but, that is why we test. we know the product works and when you plug it in you are not going to have issues.
The thing is pretty aggressive down low right now. I have a feeling the Smarty crowd will love it but, it might be too touchy for some.
Hope that clears some stuff up for you guys, and thanks for the response!
