TO MUCH BOOST?
Old Aug 17, 2003 | 05:05 PM
BLACK3500's Avatar
TO MUCH BOOST?
Just slid my stock plate foward made a very noticible difference ;D ;D ;D but ive noticed now at wide open throttle about 2000 rpm's and up my truck is making around 27 lbs of boost. why is this i thought the truck was only supposed to make around 22?? confused ???
Old Aug 17, 2003 | 05:13 PM
BLACK3500's Avatar
Re:TO MUCH BOOST?
i wont have a problem with the turbo handling that boost right
Old Aug 17, 2003 | 05:29 PM
BLACK3500's Avatar
Re:TO MUCH BOOST?
niiice ;D ;D ;D surprised how much the plate helped. cant wait til i get the new plate
Old Aug 19, 2003 | 11:40 AM
vssman's Avatar
Re:TO MUCH BOOST?
If you have the fuel, you can go up to 36-38 psi before you start to super heat the air (your then out of the efficiency range of the turbo). I have mine set to 38 for most hills & loads. I can hit 40-42 on rare occations. I definately get out of it slowly when at those pressures. Over 32 and the turbo starts to sound different. Generally, the turbo's will stay together till approx. 46-49psi. (I'm assuming an HX35/12)
Old Aug 19, 2003 | 02:15 PM
QUICKMCSS's Avatar
Re:TO MUCH BOOST?
So if I slide my stock plate forward then the boost will go up with it? I thought that it was waste gated to make 19-20 lbs? Now im ??? Do I have to make a manual boost controller or no? If not Im going to slide it forward tonight.
1997 12v Full gauges and 5"
Edited by Admin
Old Aug 19, 2003 | 02:16 PM
QUICKMCSS's Avatar
Re:TO MUCH BOOST?
TTT
Old Aug 19, 2003 | 03:23 PM
BLACK3500's Avatar
Re:TO MUCH BOOST?
i slid mine foward and didnt touch the wastgate elbow. it was like a miracle ;D
Old Aug 19, 2003 | 03:25 PM
QUICKMCSS's Avatar
Re:TO MUCH BOOST?
NICE. New project for tonight.
Old Aug 19, 2003 | 04:13 PM
03CTDCO's Avatar
Re:TO MUCH BOOST?
Stupid Question !!
What plate do you move forward to increase turbo boost ?
Explain please
Thanks, 03CTDCO
Old Aug 19, 2003 | 04:34 PM
QUICKMCSS's Avatar
Re:TO MUCH BOOST?
Its the fuel plate in 12 valve motor.
Old Aug 19, 2003 | 04:46 PM
dodgeman01's Avatar
Re:TO MUCH BOOST?
I had a #10 plate but I lost it last time I was in there : It runs super w/o a plate but I haave a 0 plate going in here soon as I get the money. Money thats funny aint it :-
DM01
Old Aug 19, 2003 | 06:12 PM
98rammer's Avatar
Re:TO MUCH BOOST?
[quote author=dodgeman01 link=board=7;threadid=18510;start=0#msg174603 date=1061329613]
DM01
[/quote]
all you have to do is slowly grind your stock one flat and then do the lever adjust
Old Aug 19, 2003 | 06:27 PM
WHIFF's Avatar
Re:TO MUCH BOOST?
[quote author=03CTDCO link=board=7;threadid=18510;start=0#msg174581 date=1061327611]
Stupid Question !!
Explain please
Thanks, 03CTDCO
[/quote]
Not really stupid at all. You've got a different engine. The plate sliding is something all of us 'properly valved' ;D folks do to get some extra HP. It's the forerunner to the Edge EZ (or comp if you go with a really aggressive plate.)
If you want extra HP, you can buy a fueling box. I would definitely get gauges first, though!
BTW...Welcome to the site. Once you start BOMBing, it's hard to stop!!!
