TO MUCH BOOST?
Just slid my stock plate foward made a very noticible difference ;D ;D ;D but ive noticed now at wide open throttle about 2000 rpm's and up my truck is making around 27 lbs of boost. why is this i thought the truck was only supposed to make around 22?? confused ???
Re:TO MUCH BOOST?
[quote author=BLACK3500 link=board=16;threadid=18510;start=#msg173648 date=1061157950]
Just slid my stock plate foward made a very noticible difference ;D ;D ;D but ive noticed now at wide open throttle about 2000 rpm's and up my truck is making around 27 lbs of boost. why is this i thought the truck was only supposed to make around 22?? confused ??? [/quote] More fuel = more boost... More fuel, more exhaust gasses to spin the turbo faster... ;) ;D ;D |
Re:TO MUCH BOOST?
i wont have a problem with the turbo handling that boost right
Re:TO MUCH BOOST?
Nope! ;D ;D ;D
Re:TO MUCH BOOST?
niiice ;D ;D ;D surprised how much the plate helped. cant wait til i get the new plate
Re:TO MUCH BOOST?
If you have the fuel, you can go up to 36-38 psi before you start to super heat the air (your then out of the efficiency range of the turbo). I have mine set to 38 for most hills & loads. I can hit 40-42 on rare occations. I definately get out of it slowly when at those pressures. Over 32 and the turbo starts to sound different. Generally, the turbo's will stay together till approx. 46-49psi. (I'm assuming an HX35/12)
Re:TO MUCH BOOST?
So if I slide my stock plate forward then the boost will go up with it? I thought that it was waste gated to make 19-20 lbs? Now im ??? Do I have to make a manual boost controller or no? If not Im going to slide it forward tonight.
1997 12v Full gauges and 5" Edited by Admin |
Re:TO MUCH BOOST?
TTT ;)
Re:TO MUCH BOOST?
i slid mine foward and didnt touch the wastgate elbow. it was like a miracle ;D
Re:TO MUCH BOOST?
NICE. New project for tonight.
Re:TO MUCH BOOST?
Stupid Question !!
What plate do you move forward to increase turbo boost ? Explain please Thanks, 03CTDCO |
Re:TO MUCH BOOST?
Its the fuel plate in 12 valve motor.
Re:TO MUCH BOOST?
I had a #10 plate but I lost it last time I was in there ::) It runs super w/o a plate but I haave a 0 plate going in here soon as I get the money. Money [laugh] thats funny aint it :-
DM01 |
Re:TO MUCH BOOST?
[quote author=dodgeman01 link=board=7;threadid=18510;start=0#msg174603 date=1061329613]
I had a #10 plate but I lost it last time I was in there ::) It runs super w/o a plate but I haave a 0 plate going in here soon as I get the money. Money [laugh] thats funny aint it :- DM01 [/quote] all you have to do is slowly grind your stock one flat and then do the lever adjust ;) |
Re:TO MUCH BOOST?
[quote author=03CTDCO link=board=7;threadid=18510;start=0#msg174581 date=1061327611]
Stupid Question !! What plate do you move forward to increase turbo boost ? Explain please Thanks, 03CTDCO [/quote] Not really stupid at all. You've got a different engine. The plate sliding is something all of us 'properly valved' ;D folks do to get some extra HP. It's the forerunner to the Edge EZ (or comp if you go with a really aggressive plate.) If you want extra HP, you can buy a fueling box. I would definitely get gauges first, though! BTW...Welcome to the site. Once you start BOMBing, it's hard to stop!!! |
