MSD Popane System
Old Jul 18, 2006 | 10:55 PM
lynnawilson's Avatar
Question MSD Popane System
Has anbody tried the propane system on a 2002 dodge 3500 HO cummings and what results and was it worth the money' positive and neg results'?
Old Jul 18, 2006 | 11:04 PM
just test "new 2 This
Old Jul 18, 2006 | 11:08 PM
one54ton's Avatar
I think propane sucks. Tank is big, hard to find sometimes and it seems limited. Water/meth is a much better/popular alternative. You could even go with nitrous if you want BIG power.
Old Jul 18, 2006 | 11:51 PM
Bart Timothy's Avatar
Propane works well if setup properly, but is a pain when it comes to the tank. If power increases are limited to 75 to 100 hp it is safe, except on the ETH (HO) engine. With a higher compression ratio and more advanced timing, it's easy to blow a head gasket using propane on an ETH.
Old Jul 19, 2006 | 06:58 AM
CTD NUT's Avatar
Oh no....you didn't.......yup, you did.....you attached that wretched "g" on the end of Cummins.
Anyway, welcome to the board!
IMO, propane is out. It is simply too easy, cost-effective and simple to get the power out of additional fueling on these 2nd gen 24v's....injector technology has come a long way and there are more modules and programmers than you can shake a stick at.....and you don't have to mess with a big propane tank.
CReed
Dec 11, 2007 01:33 PM
bluebull
Nov 4, 2007 04:26 PM
1Happycamper
Apr 6, 2006 07:47 AM
PThree
Jul 29, 2005 11:10 AM
PowerDually
Jun 12, 2005 10:51 AM
