mosquito club
Old Mar 12, 2007 | 08:12 PM
derceg's Avatar
mosquito club
After the install of my twins and mach 6's, i became a member of the mosquito repellent club. I can't believe how much smoke i leave behind me. Is there anything I can do to reduce this. Edge is turned to 1 and low smoke and still don't help. Are the injectors just too much for my bd's.
thanks
Old Mar 12, 2007 | 08:49 PM
dal620's Avatar
The Diesel Perfomance World Is A Little New To Me With Rapid Changes From The Old Mechanical Pumps To The Computer Controled Engines Being Produced Today. With The Problem You Are Describing It Sounds Like The Fuel System Is Putting To Much Fuel In The Chamber. Smoke As I Was Tought Is Unburned Fuel And Horsepower Going Out Your Tailpipe. On The Older Engines In Years Past When You Increased The Fuel To Get More Horsepower You Had To Go To A Larger Turbo. With The Electronics Though In Alot Of Cases Is Not So. The Detroits , Cummins And Cats All Have Programible Horsepower Rateings Already In The Ecm. But It Almost Sounds Like The Mods Are Conflicting With The Original Settings. I Could Be Wrong Like I Stated Earlyer The New Performance Parts Sold Are New To Me And I Have Not Worked On Any As Of Yet. Have You Tried Calling Or E-mailing The Manufacture Of The Parts You Installed?
Old Mar 12, 2007 | 09:04 PM
TheBigNasty's Avatar
Mach 6's are big injectors but with the BD twins you should be able to keep it from smoking. Unless there is something you're not telling, I would check for boost leaks.
Old Mar 12, 2007 | 09:05 PM
mikmaze's Avatar
what kind of boost levels are you getting out of the twins? all that fuel needs a lot of air, cooled air at that.
Old Mar 12, 2007 | 09:07 PM
derceg's Avatar
I have a small split in one of my boots. I have a new one on the way. I didn't even think of that being it. The turbos build boost quick and can easily get to 40 psi before i let off.
Old Mar 12, 2007 | 09:18 PM
dal620's Avatar
I Totaly Forgot About The Charge Air System That Big Nasty Said To Check. I Got Focused Ont What You Have And Not Going Back To The Basics Of Operation. Sorry About That.
Old Mar 12, 2007 | 10:15 PM
I figure as much because friends and myself included have alot of fuel like you do with much less air and we can all drive around w/o making a smoke show.....unless we want.
Old Mar 12, 2007 | 10:56 PM
Fullsizeyota's Avatar
Your post gives me a headache
It's Annoying To Capitalize Every Single Word, Not To Mention A Pain To Type It
Old Mar 12, 2007 | 11:08 PM
Mt Ram's Avatar
I Noticed That Too!!!!!! Stop It!!!!!!!!
DADDY'S DIESEL
Aug 6, 2009 09:32 PM
Sep 26, 2008 01:47 PM
planejane
Jul 17, 2003 08:29 PM
Craig93
Jun 8, 2003 10:07 PM
westcoaster
May 2, 2003 11:58 PM
