More HP
Old Mar 31, 2006 | 12:11 PM
garybg1's Avatar
More HP
I know this will sound stupid to many but I have an 02 with a Van Aaken module on it. I was told if I also used a programmer like a Superchip or Hyertech that I could increase the HP even more. Is that true can you use both? Thanks in advance for answering, I'm sure it will make me smarter.
Gary
Old Mar 31, 2006 | 12:32 PM
Mike D's Avatar
How much HP are you looking for Gary?
Old Mar 31, 2006 | 02:45 PM
Tiny's Avatar
Try a Smarty if any of your buddies have one, that is the programmer to top all programmers from what I am hearing!!
Old Apr 5, 2006 | 12:00 AM
STACKED's Avatar
the SC programer will help quite a bit but the smarty im sure is better but for alot more money
Old Apr 5, 2006 | 12:07 AM
natlchamp2k4's Avatar
I thought that if u stacked a superchips/hypertech with another fuel/timing box it would be too much timing????
Old Apr 5, 2006 | 12:37 AM
STACKED's Avatar
yeah thats what they claim but mine is stacked now and always has been. i know plenty of people with stacked timing boxes with no problems.
Old Apr 5, 2006 | 12:55 PM
garybg1's Avatar
thanks
I guess I will try it since a guy gave me an unlocked programmer he had. If it doesn't work I can always set is back the way it was. I always appreciate the help.
Gary
Old Apr 5, 2006 | 02:02 PM
HOHN's Avatar
Never stack boxes that claim to advance timing. Doing so is bad advice, and just because you know plenty of people doing it with no problems doesn't make it wise.
jh
Old Apr 5, 2006 | 02:11 PM
high country's Avatar
I've been running stacked for 70K miles......it works fine. the low end hit w/VA&supperchips together is awesome, the edge stuff just is not as agressive on the bottom as the VA
Old Apr 5, 2006 | 02:16 PM
HOHN's Avatar
I suppose now would be where I post the link to the engine that melted from stacking an EZ with a Banks Ottomind??
Anyhow, do as you please. It's only my *opinion*-- no better than anyone else's.
Old Apr 5, 2006 | 02:26 PM
RowJ's Avatar
If timing in both boxes stays fully active, you won't like it and neither will your engine!
Garybg1 - I would test it carfully and softly to start. Actually, I would not do it at all
Also... jMo
RJ
Old Apr 5, 2006 | 03:40 PM
blackdiesel's Avatar
Registered
Also... jMo
RJ
bingo!
Old Apr 6, 2006 | 01:04 AM
Ph4tty's Avatar
Look for a fueling box such as blue chip or tst if you want to stack boxes. Even a blue chip apb for $500 would add an advertised 85 hp and it'd play nicely with your va. Or sell the va and buy the smarty =P
Old Apr 6, 2006 | 10:22 AM
garybg1's Avatar
Not going to try it.
Well I guess you talked me out of it. I am not trying to make a race truck and I sure do not want to hurt my truck engine. I only pull two trailers, a four horse aluminum trailer and a boat. So I really do not need a lot more hp than I have I just always like to get the most I can without having to start modifying stuff or changing out the stock for something else. The simple stuff is easy for me and it has helped. Thanks for all the advice. This has to be the best group and the most experianced group I have conversed with.
Gary
JyRO
Jan 20, 2006 09:28 AM
robox
Oct 18, 2005 07:38 PM
j
Dec 21, 2003 10:26 AM
Commatoze
Nov 20, 2003 06:06 PM
