mach injectors
mach injectors
ok if i was to set up my truck with mach 6's and a smarty i would be around the 475 hp mark. but if i put the mach 7's in and a smarty i would be around the 495 mark right? is there that big of a difference in the two injectors? is the mach 6 the better injector? they say 7's are for twins only but the 6's are ok to run with a big single? i plan on running a phat shaft 64 with this. Opinioins? would this be pushing the stock HO vp44? when this one goes out i plan on stickin a hrvp44 in. Thanks
With an untapped wire, you could probably run an M6.
I think the M4.5 limit for HOs is spec'd by Don with the assumption of a wire-tap fueling box, but I could be mistaken.. If I am, then follow Mike D's advice and stick with M4.5 or smaller.
Maybe Don will chime in..
Dieselnutz got 440HP with his 02 HO and Mach 4's and Smarty. I got 401HP with Caatcher and Mach 4's on my ETC auto.
If you have enough air like a phat shaft 64 or 66
There should be some more numbers coming out soon.
Originally Posted by inline6power
have heard a number of people mention the smarty on here. i am totally new to this or completly oblivious. what is it and what does it do.
Originally Posted by Jetpilot
Mach 6's, Steroid B-1, and a timing box yeilds around 480-490 RWHP. I would bet the Smarty would have the similiar results.
Doug Smith
Doug Smith
RonA
14
Sep 4, 2007 11:09 AM
sway825
Dec 8, 2004 10:21 PM
fitzer
Jan 31, 2004 11:20 PM
HOHN
36
Jan 22, 2004 11:14 AM
BAD HABIT
Oct 25, 2003 11:52 PM
