Maximum Boost Levels
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
what is the maximum boost that a stock motor can handle? right now i'm getting 37-39 pounds of boost, and someone was telling me that the stock motor will fail.
37-39 seems like the norm for most lightly bombed trucks. After 38 pounds I think an HX-35 loses efficiency and I've always read that a stock head gasket is maxed out at 50 pounds. I've been running high 30's for the last 60 thousand miles with no problems. Eric
boost gauge
wondering whare the best place to tap in on a 94 12v to hook up a boost gauge never really looked into it but more boost is becoming an obession and id like to monitor my motor more than the idiot panel
First of All they make a boost fitting that taps in the intake manifold on a 12v that should fix your boost Tap Problems! Thats the stand. for the industry!
Secondly, A Stock 2000 24v with just a banks kit hitting 37? Ill just say my truck wouldnt have thought of much over 26lbs with that setup, are you sure your gauge is right? maybe a set of sticks?
On your intake manifold you'll have a port to tap in for boost. I think it's an allen head or something. It'll be towards the front of the motor on the 12v I think.
Yeah, it's a 1/8" bolt I believe. On the driver's side of the engine, inbetween the injection pump and the engine. You should see a bolt sticking out. Take that out and put your boost gauge plumbing in.
Jim
