max boost 27 lbs?
Old Oct 10, 2011 | 11:47 PM
greasy's Avatar
I blocked off the wastegate, just plugged up the hole with a 1/8 NPT plug
also slid the fuel plate back towards the cab, maybe just forward of the middle. I was running too dang hot and got tired of driving by the pyro so much
my boost is just shy of 35 lbs now, auctually I can get 37 w/o an air filter on but with stock air filter its 34-35 or so.
the silencer ring is intact, I still hear some turbo whine but not much.
no boost leaks anywhere, its holding 40 lbs air pressure when tested
pretty well pleased with how its running, no not a hotrod but a good daily driver and should be getting great economy
Old Oct 12, 2011 | 11:55 PM
IanM's Avatar
Dumb question...did you cut the waste gate line off? Mine is pinched right now and maxing out at 20psi, and I'd like to plug the line, but I don't know how to disconnect it from the waste gate??
Old Oct 13, 2011 | 12:10 AM
98fargo's Avatar
The hose should just be clamped to the elbow on the turbo, you can pinch the line off or unscrew the elbow and put a plug in. I would replace the elbow with an adjustable one myself, then you can set how much boost you want, however 20# is about right for stock fueling I think. To get more boost you need more fuel, I would say.
Old Oct 14, 2011 | 01:27 AM
greasy's Avatar
just what I did, 1/8 NPT fits in there just fine.
I havn't hit 40 lbs yet, but 35 isn't too hard.
gonna keep a good eye on it and probably get an adjustable one
truck in sig
RACER47
Oct 31, 2011 12:06 PM
Graphite600
42
Dec 11, 2004 11:18 AM
belfert
Sep 9, 2004 03:23 PM
misterKTM
Nov 23, 2003 12:39 AM
JImbo1
Aug 27, 2003 08:13 AM
