map sensor or my commander?
Old May 29, 2008 | 06:42 PM
MATTIEBOB's Avatar
today i noticed my commander at an idle was reading 1psi on boost, but then it would go back to 0psi it does it about every 30sec. or so. it keeps doing this, but idont think it is anything serious, im just curious as to what would cause this
Old May 30, 2008 | 05:29 PM
MATTIEBOB's Avatar
any ideas?
Old May 30, 2008 | 05:42 PM
JPR Ram's Avatar
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
I'd say the Commander. But then what do I know? I've never messed with one before.
Old May 30, 2008 | 05:47 PM
vzdude's Avatar
DTR's 'Go to Guy'
More than likely it is just getting a little high resistance at the connection. Do you have the wire tap or the plug and play? I have to wiggle mine every now and again to get the boost to read right.
Old May 30, 2008 | 10:14 PM
danalex's Avatar
My boost (at idle) ALWAYS reads 8psi...dunno why, but it's done it since day one. I emailed quadzilla and they said to make sure I had the wire tapped correctly (done) and to make sure I had selected the correct vehicle (done). No change. I trust the other readings so I just ignore it...would like it to read correctly, but not sure its worth repeatedly messin' with it... -2cents
Old May 30, 2008 | 10:16 PM
danalex's Avatar
By the way, anybody know where (just in case) I can pick up a new MAP sensor? I've checked most Autozones/Oreily's and they don't seem to carry them. Tks. -d
Old May 30, 2008 | 11:06 PM
xtoyz17's Avatar
Cummins, and I was actually going to say odds are good the sensor is bad.
Shawn
Old May 30, 2008 | 11:48 PM
JPR Ram's Avatar
Try these guys. Their prices are very good. http://www.hoeslidiesel.com/specials.htm
Old May 31, 2008 | 12:58 AM
MATTIEBOB's Avatar
i was thinking maybe the sensor too, because it also jumps around while driving, ie: i can be running 8psi and it will jump to 10psi and then back to 8psi. i talked to quad and they said it was probably getting a little bit more voltage and that it was more than likely the sensor
Old May 31, 2008 | 07:55 AM
hink's Avatar
That's where I got mine from. Good guys to do business with.
Old Jun 12, 2008 | 10:03 PM
MATTIEBOB's Avatar
well i ordered my new map sensor from www.hoeslidiesel.com, and it is a little bit smaller in size than the factory one. it also takes a 1 1/16" socket instead of an 1 1/4" socket. is this the right part and will it work ok on my truck?
new map sensor part#4921497
Old Jun 12, 2008 | 10:55 PM
hink's Avatar
Their website says that part # covers 98.5-00, so you should be good.
I had to go buy a deep well 1 1/16 socket to change my MAP sensor, $26 for a socket from NAPA .
kawi600
Jun 13, 2009 04:26 PM
Moobesor
Feb 23, 2008 09:57 AM
kkyle69
Jul 7, 2007 12:33 PM
Gene007
0
Feb 26, 2006 04:31 PM
Booost Almighty
Jan 1, 2006 01:41 PM
