Map sensor jump signal wire to 5v
locate the 5vdc wire, with a multimeter. that is the sensor power wire from the ecm. then locate the sensor output wire, .05vdc at idle, 5.0vdc at full boost. that is the sensor out to the ecm. all you need is to install a switch inline of the 2.
dont leave it on much, dont try to start it with the switch on. i assume you are trying to make a smoke switch?
duallydave
Jan 22, 2009 04:50 PM
Booost Almighty
Jan 1, 2006 01:41 PM
TPilaske
16
Nov 22, 2002 08:15 PM
