Mahle headgasket for performance application
Anyone had any experience with Mahle head gaskets in a performance application? I just popped an OEM head gasket while running 42 psi and thought I'd replace the head gasket with a Mahle.
Thoughts?
I don't plan on cranking up the boost any higher....I'll be sticking here I'm at.
--Sk
Thoughts?
--Sk
Cummins sells three different grades of 12v/24v head gaskets, each has a different thickness. If you running a stock piston, stock piston protrusion, stock deck height, stock head thickness, use the stock cummins head gasket that was designed for your engine.
You running head studs? I use a thick coating of locite copper head gasket spray. I would get the head decked and do a good cleaning of the block deck. I've run orings in the head over the years. The have held in up to 80psi.
Could also look into a custom MLS head gasket.
I do plan on having the head decked. I have ARP head studs to install. I only plan on running 45-50 psi after the rebuild. Think I'd need to have the head O-ringed?
Thanks for the suggestion on the Loc-Tite copper head gasket spray....I hadn't thought of that.
The custom MLS head gaskets for 12V/24V engine, phone cosmetic gaskets
they have a MLS 0.062 thou for 24V. I've never run one before, but have friend that have, they seem to work well.
http://www.cometic.com/default.aspx
tbreddiesel
Thoroughbred Diesel Performance
0
Apr 25, 2012 02:56 PM
ScienceOfSpeed
Jul 2, 2009 11:18 PM
