Mach3s
Old Sep 11, 2005 | 10:16 AM
SjLingenfelter's Avatar
Mach3s
Anyone running Mach3s and if so how do you like them? Will I hurt the stock turbo? I have a DRAG comp on it too. How smokey are they?
Thanks
Old Sep 11, 2005 | 12:31 PM
HOHN's Avatar
Just go with M4s-- cleaner, better power, better all around, imo-- though I am biased.
And, yes-- M4s with a Drag Comp can melt the turbo in about 10 seconds or so.
3s are good sticks. 4s are more gooder.
Old Sep 12, 2005 | 08:40 PM
torqueman's Avatar
I agree with Hohn go with the 4's.I'm running 3's and wish I had the 4's.The 3's can hit 1600 deg easy with stock hx35.I stepped up to B1-2 much better.You'll probobaly end up changing your turbo anyways so go for the 4's.....
Old Sep 12, 2005 | 09:54 PM
Bob Wagner's Avatar
and the price is the same
Old Sep 13, 2005 | 09:19 AM
mcoleman's Avatar
Go with the 4s but the stock turbo won't get along with them very well.
Old Sep 13, 2005 | 01:35 PM
Moose10's Avatar
So aside from Hohn's, a normal stock clutch probably won't stand up to them very long? In order to tow with these I'm assuming one would be best off to order a HD clutch and a bigger turbo at the same time as the M4's.
Sound about right?
Old Sep 13, 2005 | 04:40 PM
HOHN's Avatar
Correct. To properly use an M4, you should have a minimum of a CON OFE South Bend clutch, and a Dodgezilla 35/40 hybrid turbo.
I get away with it because I don't tow, and I don't abuse the far left pedal.
Old Sep 13, 2005 | 09:31 PM
Ph4tty's Avatar
Minimum Dodgezilla? Then properly matched you'd say,.....
Pooles tells me Full B-1
Old Sep 13, 2005 | 10:38 PM
HOHN's Avatar
I'd agree with Olee. If you want to let the M4s stretch their legs, a full B1 would do it.
jlh
lotero
14
Aug 26, 2007 11:57 PM
AlpineRAM
Apr 25, 2007 12:26 PM
