Mach 3's at idle
Mach 3's at idle
For those of you with Mach 3's, do they burn clean at an idle(250egt)? I noticed today that they make a slight haze at idle. Also when the engine is cold it lopes, but when warmed up it's smooth. Other than that, which is not a big deal, they're great!
A light haze and small lope is normal for that large of an injector.
Sometimes a reflash for winter fuel helps. Sometimes just disconecting the battery cable for a few hours helps too.
Since you have the ETH....I bet that truck will rip up the EGT gage. Your big B-1 should help the EGT's tremendously.
Don~
Don~
With cooler weather, I'm starting to see the blue haze the first few blocks after cold start. Still, it's nothing to make me run less than these Mach6's in winter.
Also, I'm not seeing any lope at idle... Maybe the DD cam is worth something after all?
brandon.
brandon.
RonA
14
Sep 4, 2007 11:09 AM
macjazzy
18
Apr 6, 2006 11:35 PM
sway825
Dec 8, 2004 10:21 PM
