Lukes link or 3rd gen track bar?
Old Apr 30, 2007 | 05:41 AM
Shelljerk47's Avatar
Question Lukes link or 3rd gen track bar?
I'm looking at doing some work to the front end of my wondering 97'. What would you guys suggest? Lukes link or 3rd gen track bar and retro fit bracket? I also need to replace my steering box, and am thinking of installing a DSS. Any thoughts?
Old Apr 30, 2007 | 01:14 PM
01RAMer's Avatar
Depends how much you want to spend. Lukes Link works good and is cheep, but is no way as good as DSS and the trackbar upgrade.
Old Apr 30, 2007 | 04:30 PM
J Lent's Avatar
I've heard nothing but good things about the Lukes Link kit. I have the solid steel 3rd gen track bar & love it, but I would probably just do the Lukes Link since they are way cheaper & working well. The DSS is by far the best steering mod for Dodge trucks. The lower column bushing fix is also a great mod. If you buy a gear box....make sure you get a 3 turn lock to lock instead of the 4 turn lock to lock. It makes these trucks a pleasure to drive.
Old May 2, 2007 | 12:49 AM
Is the 3 turn lock to lock gear box from a different year or a aftermarket box?
Thanks for the good advice!
Old May 2, 2007 | 04:01 AM
P.O.R.'s Avatar
i would go with the thuren track bar,here is a link.
http://thurenfabrication.com/stocktb.html
Old May 2, 2007 | 08:52 AM
getblown5.9's Avatar
the Luke's Link is like using a band aid when you cut your leg off with a chainsaw!
i spent the $40 on one, and a few hours installing it, and within 2 days it was back to the old loose track bar again, and i had it tightened all the way up to wear I couldnt adjust it anymore.
Old May 2, 2007 | 11:07 AM
dodgeramrod's Avatar
Lukes Link worked great for me, still going 40K miles later. Price is right.
Old May 2, 2007 | 11:18 AM
1qckdodge's Avatar
2nd for the Thuren, and its adjustable.
Old May 2, 2007 | 11:20 AM
99globalwarmer's Avatar
solid steel trackbar and the retro kit love mine handles like my dads mercilago. and its faster to.
Old May 2, 2007 | 11:41 AM
pmtg's Avatar
i like my lukes link but it only addresses one end of the track bar. the stock bushing mounted in the passenger side of the track bar isnt doing the greatest and i need to replace that as well to get it to perform as it should.
also, anybody else notice their luke's link rubbing slightly on the front diff cover? i got a 1/2" long shiny mark where my lukes is hitting...thinking about grinding a little off that side of the lukes but havent looked at that carefully to see how much material im allowed to grind.
Old May 2, 2007 | 12:17 PM
01RAMer's Avatar
When I got my Luke's Link, it came with the bushing for the other side. I am not getting any rubbing anywhere. I'm very pleased with it.
Old May 2, 2007 | 02:26 PM
XLR8R's Avatar
X 2, JLent
The steering stabilizer/sway bar drop mount combo I made was the single greatest improvement to the factory steering design.... and I installed a track bar drop mount to preserve the stock geometry:
Old May 2, 2007 | 04:21 PM
Lil Dog's Avatar
Solid Steel all the way. I have had mine on for over a year and 25000 miles with no problems. The way it improved the handling is not comparable. Also the 03 TBK works with Mag-Hytec pans..
Old May 2, 2007 | 05:12 PM
J Lent's Avatar
Originally Posted by XLR8R
X 2, JLent
That looks like some good work there! I am actually building one similar real soon with a friend of mine for his truck. He is taking the dimensions from mine & we are gonna build it.
Old May 2, 2007 | 06:38 PM
XLR8R's Avatar
Thanks!
I fabbed mine out of 304 SS - I hate RUST !
