Losing Prime. (i think)
When you tightened down the injectors, did you alternate between the injector and the connector tubes to make sure they seat together right? I know someone said something about that in an earlier post.
I popped the injectors and while putting pressure on the tubes, i slowly turned the injector till the tube popped in, then i torqued the injector, then tightened the lines
Did you pull the injectors out and inspect the copper washers? Mine were half covered in black "soot" from not being seated all the way. Just throwin stuff at ya. I dont think if they had the soot on them they would ever seat again. If they were copper colored all the way around the washer where they seat to the head then they were'nt leaking.
Crimedog
16
10-28-2006 01:23 PM
