Looking for 2" Lift Ideas
Old Dec 25, 2005 | 07:16 PM
99 cummins's Avatar
I have been trying to figure out the easiest way to lift the front and back of the truck just 2". All the lifts I can find are 3" and up. I have a set of coil spacers to install but can't find a good way of doing the rear end. I know somebody has to make a 2" lift. Give me some ideas. I use this truck for trailers and hauling so even 2" is gonna be stretchin what I can do.
Old Dec 25, 2005 | 08:23 PM
displacedtexan's Avatar
You should be able to get an add a leaf for the rear... It would stiffen the ride a bit but would be the cheapest. Or you could have your springs re-arched. The factory blocks are already 6" which is more than most care for to start with.
Old Dec 25, 2005 | 08:35 PM
99 cummins's Avatar
Everybody seemed to suggest against this add a leaf idea because it would make the truck ride stiffer. With the Bilstein's I'm runnin I don't know how it could get mech stiffer than it is. This arching is a new idea though, anymore info on the pro's con's of that and maybe where to have it done.
Old Dec 25, 2005 | 08:52 PM
It will stiffen it up some, but it shouldn't be unbearable... But it's your truck. I would do it to mine. Might wind up doing it after I level the front. Have to see after that happens tho.
Old Dec 26, 2005 | 10:14 AM
99 cummins's Avatar
Who can I talk to about getting these re-arched. The local shops here never mentioned that option so I assume they dont do it.
Old Dec 26, 2005 | 11:35 PM
ratsun's Avatar
I just put a set of Firestone air bags in and run them at around 30-40psi empty and that gave me a couple of inches in the back I needed after puting the 2" levelers in the front plus when I put my 3500# slide-in camper on, I pound 100psi in them and its still level
Old Dec 29, 2005 | 02:38 PM
99 cummins's Avatar
Still lookin for more info on this rearching thing or just more ideas.
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
theIntlEggrole
Jul 16, 2007 05:53 PM
VikingDiesel
47
May 11, 2007 12:52 AM
