Lights?
Old Sep 11, 2006 | 05:04 PM
shakessld's Avatar
Lights?
I keep reading where you can have all three lights ( fog brights and lows) on, and i would like to know how to do this other than buying a 280$ wiring harness. or if anyone know where i could get it cheaper. thanx mucho
Old Sep 11, 2006 | 05:05 PM
smokindog's Avatar
Uh, brite box is like $100 at Geno's.
Where did you find one for $280??? That's just crazy!
Old Sep 12, 2006 | 06:44 PM
coalburner400's Avatar
I think if you search the forum you'll find one even less than $100. I think there was one somewhere for ~$40. Don't quote me.
There are also postings on how to do that, plus the voltage fix for low $$.
Old Sep 12, 2006 | 08:02 PM
95ram's Avatar
Depending on what year pickup you have it will cost you about 2.50. There is two wires you have to jump.
Old Sep 13, 2006 | 11:32 AM
CTD NUT's Avatar
The jumper to keep the low beams locked on when the high beams are engaged should work for all years of 2nd gen. I did it on my 94 and 98.5 and also on a 01. That should cost $ .20 for the wire tap.
The high beam lockout mod for the fog lights is done differently depending on the year of the truck.
Old Sep 13, 2006 | 03:18 PM
Moose10's Avatar
Can anyone explain which wires to splice/cut/jump on an '01 for the low/high on at the same time mod? Possible the fog lights too???
Thnx !
Old Sep 13, 2006 | 03:35 PM
ASTAR's Avatar
I did mine. It was really easy but I forgot how. if you search the forums for a while, you'll find posts that tell you how.
Search is your friend.
Old Sep 13, 2006 | 06:21 PM
camelracer's Avatar
To keep the fog lights on with the high beams pull the fog lamp relay in the PDC and place a jumper across terminals 30 & 87 (may be labled 3 & 5).
cummins dsl
22
Jun 27, 2005 11:53 AM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
