Lift question
Old Apr 2, 2006 | 02:40 PM
Ian's Avatar
Ian
Lift question
Has anyone found a 3" lift using coils instead of blocks? I want to go bigger than a levelling kit, but I don't want to go too crazy on the pocket book and get into a 4.5" + lift. I've searched and googled it, but haven't found anything
Old Apr 2, 2006 | 05:22 PM
Cowhand's Avatar
You can order the coils from coilsprings.com and use the same Bilstien 5100's that folks are using for the leveling kit.....or you can call Sage Carli and have him put together a front/rear system that should work really well and not hurt your back pocket too bad.
Old Apr 2, 2006 | 06:39 PM
GlennRMK's Avatar
I have the D25 Skyjacker front springs on mine. Raised my front end 2 and 7/8" which is close to 3" in my book.
I don't have anything in the back and rear still sits about 1" higher then the front.
You could use an inch in the back I suppose, if you wanted.
Old Apr 2, 2006 | 07:43 PM
Ian's Avatar
Ian
thanks for the info guys.
glen - is that 2 <7/8>" just from the springs, or is that including the extra height from your 315's? I've heard that the D25s only give you 2" of height and that they're not the best spring to get. I'm looking for 3" from just the springs, then the added height from bigger tires.
Ian
Txwelder
Nov 26, 2025 01:53 AM
doomgaze
Apr 13, 2006 01:21 PM
0425004x4
16
Jan 23, 2006 06:43 PM
Txwelder
May 19, 2005 06:10 PM
lucey
Apr 21, 2005 09:53 PM
