Leveling Kit
Re:Leveling Kit
I got mine from BDS for 140 bucks. 4hr install and everythign fit perfect/ put a set of trailmaster shocks on all 4 corners and it rides like a caddy. I got the kit from Off road center in Miamitown Ohio. Talk to Tom hes a great guy. But I did drop 1k bucks that day :
DM01
:'(DM01
Re:Leveling Kit
The Off Road Center is well-established, as is Performance Offroad in Alexandria. Drew's Offroad is up 1/2 hour north of Cincy and seems okay, but I've never dealt with them personally.
Chris
(Edited by Moderator)
Chris
Re:Leveling Kit
I got the BDS spacers from Trucks In Action on Gasoline alley in Indianapolis,actually the guys had a used set that a customer had installed and didn't like so they gave me a great deal on them and they had them installed in about an hour. They have been around for quite a while and are very good. They will recommend that you get a front end alignment after the installation and if you get off road much you may have to get longer shocks if your suspension hits full drop. Because it can damage your shocks, but I havent had any problem with mine on or off road. One other thing, most Dodge trucks have one spring that is longer than the other so the truck sits slightly lop sided in the front and you will have to use a Superlift 1/2" spacer on the bottom of your spring, you can read about it on the Superlift website. The guys at the shop already had one in stock just in case, I can't say enough about their shop they have reasonable shop rates and the work is done right the first time and on time.
Re:Leveling Kit
I got mine from a company on ebay, they make some nice spacers. I wanted a 1 in instead of the 2 in and they made one and shipped it quickly. I dont have the name off hand but they are in Roseburg Oregon I believe, and you will pay about 80-120 bucks. I installed in about 3 hours with no problems. This was a great set up for my truck, prior to spacer I would rub a little on the mud flaps with my 33 in tires, now no rubbing and gave the truck a good stance. Looks better than most 2 inchers I have seen......
Rich ;D ;D ;D ;D ;D ;D
sgtdiesel
25
Jun 26, 2012 02:37 PM
