leveling kit
Old Apr 22, 2003 | 04:49 PM
quantrill88's Avatar
leveling kit
id like to run 315/75R16's when i get tires next so ive been thinkn bout a daystar leveling kit. heres my question, at present i dont notice my truck being &quot;off-level&quot;, will adding this make it sit higher in the front than the back?<br><br>anyone that has done this, how do u like it? and how hard was it to install?<br><br>thanks in advance
Old Apr 22, 2003 | 05:26 PM
ridofpwrstroke's Avatar
Re:leveling kit
I put the kit on the front and it was still about an inch lower. The kit was very easy to install. The 315's also fill up the gaps very nicely. I do rub with stock wheels at full lock. Besides that, it runs great.
Old Apr 22, 2003 | 08:59 PM
Stamey's Avatar
Re:leveling kit
You might not need a leveling kit. DodgeMan01 says he is running 315/75R16's and has NO rubbing at all, with stock rims. I couldn't believe it but he swears it's true. There's a thread a while back when we were discussing tire sizes and what would fit.<br><br>I KNOW that 305/70R16's will only rubb a little on the bottom axle tracking arm at full lock, with stock 16x7.5&quot; aluminum wheels, but the same size tire rubs the fender well with 16x10&quot; Mickey Thompson Classic II's (4 3/8 backspacing), and requires the leveling kit.<br><br>My truck sits different and it took a little getting used to at first, but I like it/don't notice it now. My truck did site a little lower in the front. 1700 lbs. of cement in the back almost brought the back down to level with the front before the leveling kit.<br><br><br><br>Chris
Old Apr 23, 2003 | 06:20 AM
Timinva's Avatar
DTR Advertiser
Re:leveling kit
After seeing Stameys truck at the last meet, I went out and ordered a leveling kit for mine. I got it from Jackit.com and installed Bilstein shocks that are 2&quot; taller. It was pretty easy to install but I needed to compress my springs a couple of inches to reinstall them, the axle just wouldnt drop away far enough even w/ the sway bar disconnected. Mine is still slightly taller in the back but looks good. The new Bilstiens really ride good compared to the stock shocks. Tim
sgtdiesel
25
Jun 26, 2012 02:37 PM
dodgeboy59td
26
Dec 31, 2002 12:05 AM
UTAH
32
Dec 11, 2002 11:47 AM
Fishin2Deep4U
Dec 10, 2002 07:34 PM
j
17
Nov 10, 2002 07:57 PM
