Laser cut DV's
Laser cut DV's
Will someone please compare lasercut dv's to my stock 181's with 370 injectors.
What kind of power increase will I have if I go with the laser cut dv's. What makes the laser cut dv's so much better?
Most importantly, where do you get them at?
I had a custom "HOT" plate and PDR 370's in my 215 pump.
I installed JR Adkins laser cut DV's.......well....... and JUST ABOUT cover it!
You can get them from JR Adkins of Adkins Diesel Performance 317-281-3130 for $250 with core exchange......but let me warn you these are NOT for a stock charger. They easily make enough boost to blow one sky high!
I run laser cut 191 dv's from Piers and they add a huge bottom end punch and feed 370's VERY well, to say the least. That said, the 181 dv's in your 215 pump do work quite well with 370's already.
stock600
14
02-25-2008 11:21 AM
