Larger Turbine housing
Old Jun 14, 2008 | 05:56 PM
biggator60's Avatar
Is it neccesary to put a larger turbine housing on my stock turbo when using the tst cam plate #6, they say after 270 hp you should use a larger housing,
i already have 50 hp DDP injectors and a 4" exhaust, installing gauges as soon as they arrive....any suggestions??
Old Jun 21, 2008 | 06:02 PM
sully85's Avatar
it depends on how you drive and what you are gonna do with the truck. Daily with no load you'll be fine for a while if ya plan on leaveing yer foot in it the egts are gonna get a lil hairy pulling a load or city driving
Old Jun 21, 2008 | 11:53 PM
bmoeller's Avatar
At bare minimum, I'd get a bigger housing. Would suggest a HTT 62/12.
Old Jun 22, 2008 | 03:28 PM
Tate's Avatar
Use your EGT's as a guide if you need a bigger housing or not. Diesel Dave is running a 10 plate, GSK and laser cut DV's on the stock turbo. His temps are pretty good, and he has put down 350hp at the last two dyno's we've had.
SuperDave4x4
Jul 24, 2005 08:26 PM
600 Megawatts
Jan 30, 2005 10:51 AM
subs1000w
Aug 20, 2004 02:12 PM
dart440_72
Jul 10, 2003 08:00 PM
