Large Meats
From: My head lays down in Murrieta, but the day light hours are spent in San Diego, Ca.
This weekend i will be installing a two inch leveling kit on my truck. I'll by putting on new tires as soon as i get that tax check. I was gonna go with 315 75 16's (35's), but now that we've all seen XLR8R's awsome looking '05 riding on 37's, maybe bigger.
So my question to you guys is, what is the largest tire you have stuffed under your gen 2 trucks with only a two inch lift? Post some picrures so we all can see those large meats.
If you were to have longer or adjustable control arms you could push the axle forward and maybe, just maybe, fit 37's. With only the 2" and factory arms you can fit 35's but they will rub with little effort. What size wheels are you going to run with these 315's?
well, my original plan was the 315's and the stock wheels.
Oh ok, 315's on stock wheels shouldn't rub w/o some major terrain. Only problem is you are putting a 12" wide tire on a 8" (or are they 7", I forgot
) wide rim so they way wear a little uneven, but not bad.
315's on stock 8" Al wheels ride, track & wear better than I expected!
Pic will be showing up on another thread .... Here
RJ
RJ
here is my 2" and 35's...looks very big in person, you'd think they were taller than 35's!!! 37's will not fit with a 2" spacer unless you trim sheetmetal, and use an aftermarket wheel with less offset
5.0 Mustang Man
38
Sep 19, 2008 03:01 AM
pcburnout
Sep 7, 2005 08:25 AM
