Know nobody runns a garrett on a ctd but...............
Old Aug 12, 2005 | 04:26 PM
Ocmechanx's Avatar
I happen to have a gt4082 garrett turbo, comperssor side, inducer 58mm, compressor 82mm, exhaust 77mm.
What would this be compairable to,?...........schwitzer,holset,ect.
haven't had that much exp upgradin turbo's bein that they cost pruty good $$$$
So I been scavengin some from truck yards
any turbo guru's help ? maybe ?
Old Aug 12, 2005 | 09:07 PM
Ocmechanx's Avatar
guess nobody know......................
anybody
Old Aug 12, 2005 | 09:57 PM
Rods's Avatar
400HP give or take a few , usally theres a 175 to 200 HP diffrence in gas hp to diesel 100/10 for gas and 80/10 for diesel , not all the time but its close , and u need a adaptor T04 to T3 i know were u can get those to if u need one
Old Aug 12, 2005 | 10:04 PM
Ocmechanx's Avatar
Any chance ya seen or heard of a large housin garrett used on a modded truck like ours?
and adapter r ya talkin bout the, exaust manifold side? cause yea been tryin to figure out what I needed and where to get it,..............that is if this turbo is any better than my 35/40 been talkin bout in the other post, cause I need somethin bad
Old Aug 12, 2005 | 10:13 PM
Rods's Avatar
there some out there , mine uses a garret center section but with different housing and wheels , the adaptor lets u bolt up T04 style turbo flange (garrett) to the factory manifold , 105$ for one , As for being better than yr 35/40 ,,, depends on who done it some do a little more than others when doing hybrids that garret u posted supports 585 on gas so its going to b low on diesel , compared to that hybrid , u want to make 400 to 600 with a garett look for some thing that flows 79lbs per minute
Old Aug 12, 2005 | 10:22 PM
Ocmechanx's Avatar
well check out the exhst housing post thats the same turbo
all it is is a stock hx40 center section and compressor housing off a 8.3 cummins and 35 12cm2 factory housing and I have no idea what it flows comaired to the gt40
if it helps the garrett came off a dt466 int engine in a dump truckaround 7L I think
Old Aug 12, 2005 | 10:27 PM
Rods's Avatar
is it a new dt466 ?? i know the older ones use TO4Es the GT turbos r supposed b nice with the bearings and such , but i dont think yr going to c much diffrence , what is the A/r on the turbine housing ??
heres more info on the garrett
GT40
Compressor Turbine Wheel
HP Displacement Whl Dia. Trim A/R Wh Dia. Trim A/R
370-650 ,3.5-5.0L 82mm 50 .58 77mm 73
if im not mistaken the 40 uses a 60 mm were thats a 50 for the compressor and max is 5.0 liters
find a gt 42 94 ,,, find me one also
Old Aug 12, 2005 | 10:52 PM
Ocmechanx's Avatar
Its actually off a 95 model and it just has regular friction type bearings, and I also saw that the one on garretts web was just for 5.0, but p/n didn't match up with any on the website can only figure it is too old, but it does have inducer about 52mm large side bout82mm and exhaust is bout77mm
wilderness
Jul 31, 2014 09:58 AM
irocpractice
May 25, 2013 11:20 AM
JCLeary
25
Feb 6, 2008 12:14 PM
welder27
Dec 2, 2004 01:19 AM
jaconst
May 29, 2004 09:44 PM
