keep egt's down
Old Dec 30, 2006 | 04:00 PM
olwhitey's Avatar
keep egt's down
i got a comp box and 4 in. exhaust. i was wanting to get some injectors but nothin real big. i was lookin at like jammer 2 or 3's but i was wonderin if my egt's would get too high with my stock turbo. what kind of turbo upgrades would i need if i get these things.
Also, would i be able to tow like a gooseneck with a truck on it or just a heavy load in general. i dont tow that much but would still like to have the option without having super high egt's. any comments will help
i plan on gettin some gauges too,btw where do u all get those ISSPRO gauges, i see a lot of ppl hav so they must be pretty good
Old Dec 30, 2006 | 04:07 PM
blackdiesel's Avatar
Registered
isspros are good. how heavy are you going to tow? if you turn the box off you should be ok up to a point. that is with the 2's. you may get away with the 3's or 4's if you would want to bump up to a sps 62 or some turbo of the like....
Old Dec 30, 2006 | 05:23 PM
olwhitey's Avatar
i would prolly pull a gooseneck and truck or some hay, idk i jus want to keep my options open and not bomb my truck so muh that i eliminate the possibility of towing anything. is the comp box not a good box for towing or what u all think?
Old Dec 30, 2006 | 05:27 PM
Registered
if you just had the comp that would be ok. you could set it on 3x5 or so and tow with the stock turbo.
i have towed with jammer 4's and a comp before. had the comp on 1x1 and i got way to hot!
Old Dec 30, 2006 | 05:53 PM
olwhitey's Avatar
would i be fine towing with the comp on 1 or 2 if i get stage 2 or 3 jammers and a bigger turbo or even twins. why does the comp make the egts so hot? would i be better off with a different box or untappin the wire
Old Dec 31, 2006 | 01:03 AM
Tate's Avatar
Judt turn the box off. Keeps your temps down, but still boost fools.
Dave88LX
Sep 2, 2025 10:30 PM
Stovetop535
17
Jan 31, 2008 11:40 AM
StrokeThisCTD
15
Aug 5, 2005 02:45 PM
j28s
Nov 20, 2003 02:56 PM
