Upgrades to keep EGT's down
Old Jan 30, 2008 | 07:07 PM
Stovetop535's Avatar
Hey i was just curious if there was anything out there besides a new air intake, or exhaust that will help keep my egt's down
Old Jan 30, 2008 | 07:11 PM
dmscumnz's Avatar
Water/methanol injection.. you can drop between 50-400 degrees, all depending on fueling and mods. other advantages are cleaning effects of the hydrogen as well as the added power from the meth, oh and did I mention it COOLS things down??!?!
Old Jan 30, 2008 | 10:15 PM
rjm022's Avatar
new inter cooler. new turbo, or new exhaust manifold
Old Jan 30, 2008 | 10:21 PM
Jfaulkner's Avatar
Muted User
a new turbo is most effective.
Old Jan 31, 2008 | 01:55 AM
RRC's Avatar
RRC
Thumbs up
Check out T H I S thread I started. Good Luck...
Old Jan 31, 2008 | 02:54 AM
Kman9090's Avatar
Your not running any chips or prgrammers so how are your egt's so high? What kind of egts are you seeing?
Old Jan 31, 2008 | 07:14 AM
MOJO1's Avatar
I would like to know what some people think about the years making a differance. Does the years really make that big of a differance for as how HIGH your EGTs can go to be safe.Some say the later can exceed 1350-1400 all daylong SOME HELP PLEASE!
Old Jan 31, 2008 | 08:00 AM
#2 only's Avatar
I'd recommend something with some good timing.tst or smarty.All the other small mods won't do much and a turbo won't help without fuel,may even raise egt's.
Old Jan 31, 2008 | 08:29 AM
Kman9090's Avatar
yes 1350 1400 are safe all day long. SOme guys can see 2000 going down the track. 1500 you are starting to get pretty warm.
Old Jan 31, 2008 | 09:03 AM
haloman's Avatar
it really depends on how much timing there is in a truck. Alot of timing plus high egts equals even higher temps at the pistons.
Old Jan 31, 2008 | 10:23 AM
AH64ID's Avatar
Smarty Jr... Just enough timing on the 40hp setting to keep EGTs in check, and to add some power.. but no extra fuel....
Some say the 04.5 plus was built to handle more heat, but I still feel that 1250* continuous, 1350* max is the safest.
Old Jan 31, 2008 | 10:51 AM
jmccart's Avatar
Smarty or a Smarty Jr. I have had a gauge for a while. I have watched my gauge through a Hypertech, DIablo, and even stock. Smarty drastically lowers EGT's on all.
Old Jan 31, 2008 | 10:56 AM
Erik@LCD's Avatar
Smarty for sure. On 7, I havent seen more than 1280, even towing 13-14k over some mild hills.
Old Jan 31, 2008 | 10:57 AM
AH64ID's Avatar
Depends... are you looking just for lower EGT's or do you plan to mod the crap out of it?
Old Jan 31, 2008 | 11:06 AM
Jfaulkner's Avatar
Muted User
Exactly, future mod plans make a big difference on which direction you go. Timing will only do so much, water injection is just a crutch. The only real way to get colder air out is to put colder air in, in relation to the amount of fuel you inject. If your not planning on any big fuel mods then timing and intake/exhaust may take care of your problem. If you plan on stacking boxes or adding injectors then that stock charger needs to go.
