Just a Tease...
Old Sep 16, 2003 | 04:15 PM
  #151
Battering Ram's Avatar
Re:Just a Tease...
Leak is still there... had to buy another stud for the Banks High Ram. Once I get a chance I'm gonna pull it off, sell it, and go back to the stock one. I also have to replace my dying PE4200. Gotta get the new pump and intake hat on before D/FW dyno day so I can get some numbers.
Horace
Old Sep 16, 2003 | 04:18 PM
  #152
TxDieselKid's Avatar
Re:Just a Tease...
[quote author=Battering Ram link=board=7;threadid=18103;start=150#msg185548 date=1063746939]
Horace
[/quote]
What about that injection pump? ??? ;D :P
Andrew
P.S. Your brother'f friends are losers.
Old Sep 21, 2003 | 06:14 PM
  #153
SjLingenfelter's Avatar
Re:Just a Tease...
When is the D/FW day? What do you think you will run?
Old Sep 21, 2003 | 06:25 PM
  #154
J.R. Adkins's Avatar
Re:Just a Tease...
How is that slipping clutch???
J.R.
Old Sep 21, 2003 | 06:44 PM
  #155
Re:Just a Tease...
So, get that leak fixed the other day or were you too busy at the DooDat BBQ? ;D
Andrew
Old Sep 21, 2003 | 07:07 PM
  #156
Re:Just a Tease...
Andrew, Yes I fixed the leak this weekend ;D. I have not ran at WOT yet due to wet roads, but my EGT's are down and it smokes much less.
TxRedneck, I plan on attending the D/FW dyno day. I don't like to speculate hp numbers because I really don't have any idea. I would venture to guess the mid 500's with the injectors I have with the HO pump.
Horace
Old Sep 22, 2003 | 02:25 PM
  #157
Re:Just a Tease...
That will be good. Let us know what number you get.
Old Sep 24, 2003 | 12:07 PM
  #158
Re:Just a Tease...
[quote author=Battering Ram link=board=7;threadid=18103;start=150#msg187452 date=1064189243]
Horace
[/quote]
Horace,
It has been dry for several days now, SHOW ME THE BOOST!!! ;D
Old Sep 25, 2003 | 01:12 PM
  #159
Re:Just a Tease...
Horace,
Its been dry now..tell us the numbers!
Old Sep 25, 2003 | 04:46 PM
  #160
MCummings's Avatar
Re:Just a Tease...
Rumour has it,, a pump that he needs to make more power, may not be on his truck at the moment, and he's trying to solve that problem.
But, Like I said, it's only a rumour.
(Now, I didn't say his truck was missing any pumps,, just a pump he needs to make more power )
Old Sep 25, 2003 | 09:35 PM
  #161
Re:Just a Tease...
[quote author=MCummings link=board=7;threadid=18103;start=150#msg189322 date=1064526413]
[/quote]
I think he is forgetting that clutch also!! :P
Old Sep 26, 2003 | 12:17 AM
  #162
MCummings's Avatar
Re:Just a Tease...
[quote author=TxDieselKid link=board=7;threadid=18103;start=150#msg189479 date=1064543737]
[/quote]
I've got some super glue we could use for the dyno run.....
Old Sep 26, 2003 | 12:46 PM
  #163
formula's Avatar
Re:Just a Tease...
[quote author=Jim Fulmer link=board=7;threadid=18103;start=135#msg181314 date=1062857207]
Ed West's pull truck probably has the biggest set of Twins I've seen, his hybred top turbo is about the size of a HT3B(physical or maybe a tad bigger) and his second one is off of a stationary diesel and is a monster.
Jim
[/quote]
Look familiar? ;D ;D
Old Sep 29, 2003 | 12:48 AM
  #164
Re:Just a Tease...
Well looks like the final results are in after all the work I have done to the truck. I FINALLY got to open her up for the first time with NO major boost leak. Max boost at WOT spiked at about 70psi and my EGT's never hit 1300. It was pretty cool tonight at just under 70 degrees. I gotta dyno next to see what I have.
Horace
Old Sep 29, 2003 | 08:57 AM
  #165
Re:Just a Tease...
You need toget rid of those towing injectors! :P
Actually 1300 aint bad for those that you got! 8)
I bet spoolup got a little better also since the leak got fixed?
You going to the rally in Kerrville?
Andrew
