Just a Tease...
Old Sep 6, 2003 | 09:06 AM
  #136
Jim Fulmer's Avatar
Re:Just a Tease...
Ed West's pull truck probably has the biggest set of Twins I've seen, his hybred top turbo is about the size of a HT3B(physical or maybe a tad bigger) and his second one is off of a stationary diesel and is a monster.
Jim
Old Sep 6, 2003 | 03:35 PM
  #137
Battering Ram's Avatar
Re:Just a Tease...
The twins on the last page has an hybrid turbo on the manifold also that has an HX60 compressor on it which is bigger than an HT3B. I'm not sure the size of the primary charger but it looks like a monster.
Old Sep 7, 2003 | 12:08 AM
  #138
TxDieselKid's Avatar
Re:Just a Tease...
[quote author=Battering Ram link=board=7;threadid=18103;start=135#msg181409 date=1062880535]
The twins on the last page has an hybrid turbo on the manifold also that has an HX60 compressor on it which is bigger than an HT3B. I'm not sure the size of the primary charger but it looks like a monster.[/quote]
Horace,
that set of chargers on the last page is HUGE. The HX60 has been modified from what I understand. I think Mitchell or Scheids would have a bigger set on their "pulling" trucks, but I don't know for sure, as the guy that runs that system is crazy enough to try it anyways.
Also Horace, another little birdie tells me now that you have found a boost leak? :- That sucks, or blows depending on how you look at it! Now tell me, are you making this 70lbs WITH the boost leak, or is it something new? ???
Andrew
Old Sep 7, 2003 | 09:58 PM
  #139
Re:Just a Tease...
Also Horace, another little birdie tells me now that you have found a boost leak? That sucks, or blows depending on how you look at it! Now tell me, are you making this 70lbs WITH the boost leak, or is it something new?
A little birdie told me he has some new injectors that you can literly WATCH the gas gauge go down when you step on it!
Well the birdie was wrong about the injectors but right about the boost leak. I built a piece out of PVC to preasurize my intake system. I found such a big leak on the intake hat that I couldn't preasurize the system even with a 3hp gas compressor, it was that big of a leak. Yes I am still hitting 70psi with the leak. I will fix it this week then I will see where my boost is at then.
Old Sep 7, 2003 | 11:28 PM
  #140
MCummings's Avatar
Re:Just a Tease...
I have a "kit" in the works for pressurizing, and testing the I/C. Probably be coming out in Early November.
Horace,, That sounds pretty bad. Was it a crack? Blown gasket? A space time continuim? Alien Vortex?
BTW,, Dropped the tranny out of my 4by Sat. night. Snapped input shaft. I get to R&R the shaft, and install the tranny Monday night! Whoo-Hoo : That thing is heavy,, maybe we shouldn't have dropped t-case, and all?
Merrick Cummings Jr
Old Sep 8, 2003 | 01:03 AM
  #141
BigBlue's Avatar
Re:Just a Tease...
How are the trucks coming along merrick?
Old Sep 8, 2003 | 07:39 AM
  #142
Re:Just a Tease...
[quote author=BigBlue link=board=7;threadid=18103;start=135#msg181845 date=1063001021]
[/quote]
yea Merrick, you getting twins or what? ???
Old Sep 8, 2003 | 06:19 PM
  #143
MCummings's Avatar
Re:Just a Tease...
Well, in a little bit, after an oil change for a friend, I get to R&R The input shaft, then bolt it all back up.
Am I getting twins? It allready has twins ;D
I don't have much info right now,, but should now more tomorow night. No need to hijack the thread,, again,
Merrick Cummings Jr
Old Sep 9, 2003 | 09:36 AM
  #144
Re:Just a Tease...
[quote author=MCummings link=board=7;threadid=18103;start=135#msg182156 date=1063063186]I don't have much info right now,, but should now more tomorow night. No need to hijack the thread,, again,
[/quote]
It's not hijacking if your going to get the same twin system! :P ....
Andrew
Old Sep 12, 2003 | 05:28 PM
  #145
SjLingenfelter's Avatar
Re:Just a Tease...
So whats the good news now? Anything? Theres gotta be something. ???
Old Sep 12, 2003 | 06:53 PM
  #146
MCummings's Avatar
Re:Just a Tease...
Got the Billet shaft in. Goods will be here ~Thursday,, and I've got another suprise.
You'll be hearing from me Next Weekend!
Merrick Cummings Jr
Old Sep 12, 2003 | 10:56 PM
  #147
James Lucas's Avatar
Re:Just a Tease...
[quote author=TxRedneck link=board=7;threadid=18103;start=135#msg184070 date=1063405727]
[/quote]
HECK YA!!!!!!
I picked up my truck tonight from Mark Kendrick and my Twins
[glow=red,2,300]ROCK[/glow]
Thanks Mark for doing such a great job....
The details of all that he did will follow but I am so tired and gotta get down to Houston......
James
Old Sep 13, 2003 | 05:52 PM
  #148
MCummings's Avatar
Re:Just a Tease...
Well, Just in case you are curios, an HX-40 and a 3B is more than enough to break stuff.
I just cracked my Transfer case last night doing some 30PSI launches with my 36x14.5 Mickey Thompsons on the street.
I have an aluminum welder coming by tomorow to weld her up. I don't think it'll hold. So if anybody wants a used T-Case with a welded crack, that will work great for near stock trucks, I've got one for cheap.
I have some plans for the T-Case, and it won't involve the words, "New Process".
Merrick Cummings Jr
Old Sep 14, 2003 | 02:23 PM
  #149
Re:Just a Tease...
Horace,
Anynews on the boost leak? Did you get it fixed yet?
Old Sep 16, 2003 | 01:56 PM
  #150
Re:Just a Tease...
Come on Butterball whats today's news? ;D
