Just added gauges
Old Aug 17, 2009 | 10:02 PM
jcamron's Avatar
Just added gauges
Just added Glowshift gauges to the old beast. Had a problem with the sender on the fuel gauge but Glowshift immediately sent another sender. Installed it and it seemed odd that there was no fuel pressure. Then the engine quit. Think I lost ANOTHER fuel pump! The fuel pump in the tank S*****. What to do? The last time I replace a fuel pump in a gasser was in 1957. The Cummins may be great but everthing around it is junk!!! I may be going back to a gasser!!!
Old Aug 18, 2009 | 02:58 PM
RedneckRebel222's Avatar
There is no fuel pump in the tank on these trucks, only a sending unit and the pick up tube. the fuel pump is on the back end of the drivers side of the block. Look behind and down from the injection pump, you'll see what looks like an oil filter. This is actually your fuel filter, you can trace the lines back to find your lift pump from there.
And, IMO, gassers suck, real trucks dont have spark plugs!
Best of luck!
Old Aug 18, 2009 | 05:05 PM
jcamron's Avatar
Mod moved the fuel pump to the tank
Best of luck!
A mod moved the fuel pump from the side of the engine to the fuel tank. The shop did the first one in 2007. I lost that one in Wyoming in 2008 almost 1 year to the day of the first install.
bull_chips
May 5, 2008 04:05 PM
Kman9090
29
Dec 6, 2007 06:43 PM
coontz0473
17
Sep 22, 2006 03:52 PM
Duckman1993
Sep 12, 2006 07:50 PM
dieselnewbie
14
Dec 23, 2004 02:01 PM
