J-Hook
Old Jul 6, 2008 | 07:57 PM
daboocru's Avatar
J-Hook
This may be a dumb question but i am not sure what a j-hook does and what performance if any does it give you. I have heard alot of people talking about them on here but not sure what it does for you.
Old Jul 6, 2008 | 08:33 PM
2001 CTD's Avatar
a j hook prevents the wastegate from opening which alows you to create mor boost. if your truck has an auto it will have a hy turbo which requires a j hook. since you have a 6spd you need a orphice fitting that screws in your turbo. hope this helps
Old Jul 6, 2008 | 08:56 PM
daboocru's Avatar
Not sure what an orphice fitting is?? Any ideas where you can get them. Also if i get one would it throw any codes for building more boost?? Thanks for all of the help!! Just getting stating into all of this so all help is greatly appreciated.
Old Jul 6, 2008 | 09:53 PM
scottsjeeprolet's Avatar
Otherwise known as the Boost elbow. They usually come with a box that does boost fooling. Your turbo is a HX35 not the HY35 which requires the J hook.
Old Jul 7, 2008 | 02:12 AM
Ed ke6bnl's Avatar
my automatic 98.5 came with an hx 35 installed and an hy in a box. Why would someone put the hx in the truck has 275 injectors, and edge ez been wondering hope I did not mess up the thread thanks ED
Old Jul 7, 2008 | 11:06 AM
PaulDaisy's Avatar
I think the HX puts a bit more air out than the XY, so it is a mild upgrade to go with your 275s on an auto.
Old Jul 7, 2008 | 11:50 AM
Ed ke6bnl's Avatar
Thanks kinda what I thought ED
Old Oct 13, 2008 | 06:44 PM
daboocru's Avatar
I'm confused about these posts. I got 2 different answers and just want to clear things up before i buy something.
Auto --> HY --> Boost elbow
6spd --> HX --> J Hook ????????????
Old Oct 13, 2008 | 06:48 PM
daboocru's Avatar
Think i got those backwards and miss read the post.
Auto --> HY --> J Hook
6spd --> HX --> Boost Elbow
Old Oct 13, 2008 | 07:46 PM
Destination's Avatar
this is correct you have a hx/35 and a boost elbow is what you would want to buy
Old Oct 14, 2008 | 12:30 AM
97 D-Tec's Avatar
a boost elbow is basically a L fitting (some arent always L shaped) with a set screw on the out side of it. when you turn the screw you can either turn up the boost or turn it down depending on ur application.
It looks like the one in my picture (goldish thing with the line going to the waste gate
http://i223.photobucket.com/albums/d...1/IMG_0462.jpg
Old Oct 14, 2008 | 12:38 AM
Pork's Avatar
the stock wastegate is set at 20psi on an HY35. i was thinking about gettin j-hook, but after i put on the drag comp it can push that little HY to 30psi with the wastegate open! i was like "well...guess no need for the j-hook"
Dodgezilla
Mar 12, 2003 01:50 PM
j28s
Dec 16, 2002 08:15 PM
Mr. 45
15
Dec 12, 2002 10:51 AM
tomsauto
Nov 18, 2002 07:22 PM
admin
27
Nov 12, 2002 04:47 PM
