isspro trans temp?
Old Sep 6, 2005 | 11:25 PM
GSP's Avatar
GSP
isspro trans temp?
What/How is/does the sending unit work on a Isspro. All I know is seeing the picture of the gauge only.
How does the sending unit install , any pix? What about this '94 trans line that has a fitting??? Is a electric wire run from a sending unit to the gauge or is it mechanical like a Stewart Warner water temp gauge?
Rick
Old Sep 6, 2005 | 11:27 PM
BigBlue's Avatar
The sensor just screws into the line and you attach a wire into the gauge.
Old Sep 7, 2005 | 01:03 AM
Homestead's Avatar
2 wires run down to the senser. There is a driver/amplifier box to mount under the dash somewhere which drives the guage.
Simple install, not hard at all.
Old Sep 7, 2005 | 09:48 AM
storx's Avatar
Rick
my isspro had a 3/4 sensor probe.....i just took the tranny pan off........drilled a hole on the bottom out of the way from hitting anything when the pan was put back on and used a 3/4 bolt and nut and screwed them together with the nut inside the pan and then i braised the pan and the nut together.......waalaaa.....tranny drain plug/ aka spot to screw in tranny sensor...... "man sometimes when i got nothing better to do i come up with the best ideas for installations....."
b.lee
Mar 7, 2007 02:27 PM
fade94
Feb 22, 2007 08:22 PM
supercharger
Feb 10, 2007 08:26 PM
BuckeyeRed
Oct 17, 2006 10:44 PM
Dufrain
Aug 26, 2004 10:47 PM
