Interesting Mod
Old Jun 15, 2004 | 01:39 AM
BigBlue's Avatar
Interesting Mod
Was reading a couple of sights and stumbled upon this mod. Apparently, you can put a resistor inside the intake air temperature sensor and trick the computer into thinking it's cold outside, that way it will advance the timing and up the power. That's what I heard. Any of you guys/gals try this?
Old Jun 15, 2004 | 09:35 AM
2500CTD's Avatar
I heard about this on the Magnum engines. Never heard of it on the Cummins though. Almost did it on my Dakota but fortunately traded it in for my Diesel
Old Jun 15, 2004 | 10:52 AM
DieselDaze's Avatar
The same can be done on many import cars. I have an older Toyota Celica that I have wired up with a switch. The switch activates a bypass harness that runs the current through a resister. This tricks the computer into thinking that its cold out and the timing is increased along with the fuel mixture.
For my Toyota, its not recommended to run like this for long. But because of the gearing I have installed, turning on the switch is helpful when fast acceleration is needed.
Rich.
Old Jun 15, 2004 | 12:11 PM
rattle_rattle's Avatar
I'd like to hear more detailed info on this.
Old Jun 15, 2004 | 11:44 PM
JR2's Avatar
JR2
I looked into this when I was really after more HP. The guys I talked to said you might gain 5-10 hp doing it and you lost some mpg. In the end I skipped this mod.
I do know some guys have moved there IAT to the intake horn or the air box and got the same results. The advantage of doing this is that its easier to clean and if you run an exhaust break its a good idea to clean the sensor every couple of oil changes.
I believe practical solutions diesel makes a harness to move the IAT.
Old Jun 16, 2004 | 02:11 AM
BigBlue's Avatar
Hmm. I was planning on doing this to a 99 Ferdl
Old Jun 16, 2004 | 01:08 PM
Forrest's Avatar
Muted User
I would imagine it'd shorten the life of the cat.
Old Jun 16, 2004 | 03:01 PM
BigBlue's Avatar
It's hard to shorten the life of something that's not there.
Old Jun 17, 2004 | 10:34 PM
JR2's Avatar
JR2
Big Blue, skip the IAT on the Ford. Put a 10K ohmm resistor on the ICP and be happy.
Check out this page for the how to: http://www.forgotton.net/mods/index.html
Old Jun 18, 2004 | 03:35 AM
BigBlue's Avatar
This is on a gas truck, not a diesel.
jmccart
Dec 19, 2007 12:49 AM
jamesbfishin
Jul 7, 2007 08:25 PM
wap
14
Apr 23, 2007 06:46 PM
RAMV
Jul 14, 2004 12:08 PM
