Installed new headunit, no sound
Old Dec 1, 2006 | 02:04 PM
mysterystench's Avatar
Ive searched and searched and havent found much on the topic, but here's my problem:
I took my factory head unit out and replaced it with a decent quality JVC, When i bought the wire harness from circuit city, they said that's all I'd need, and I trusted them because they install there. Anyways, I'm getting very little sound through 2 speakers up front and ZERO sound from the other speakers. I'm guessing it's pre amped or something but ive asked a bunch of installers and they say they've never run into problems, even with the stock infinity systems
any ideas?
Old Dec 1, 2006 | 02:30 PM
Sea:\>Drive's Avatar
Do you have the Infinity System?
Old Dec 1, 2006 | 02:53 PM
LanceD's Avatar
hook the pink wire from the harness to the blue wire on the JVC
Old Dec 1, 2006 | 02:58 PM
yfz450guy's Avatar
power up the power antenna wire.?
Old Dec 1, 2006 | 03:06 PM
bnold's Avatar
More than likely you do not have your amp power signal wire connected.... With most newer head units there is a blue? wire for signaling an amp to power up. If you have the infinity system as mentioned there is an onboard amp that has to be turned on by your head unit...
Old Dec 1, 2006 | 03:20 PM
P.J's Avatar
P.J
Like others have said, without the blue wire (or power antenna hook up) connected you'll get NOTHING. Sounds dumb, cause we all know there is no power antenna, it is just a 12V signal to power up the amps/crossovers.
Old Dec 1, 2006 | 09:22 PM
THANK YOU all so much! It was just as simple as you all mentioned, hooked up the blue wire and it was all good.
quick, easy and free fixes always make me happy
thanks again guys!
Old Dec 3, 2006 | 07:05 AM
LanceD's Avatar
did you hook up the blue wire or the blue/white? because on some head units when you turn on a CD it takes away power from your antenna, but on yours it will turn the amps off, so if it does that, switch it to the blue/white wire.
Old Dec 3, 2006 | 12:22 PM
b.lee's Avatar
yup, gotta love those remote wires.
I returned a cd player once because I didn't hook up the remote wire. lol.
CTD2001
Jul 14, 2006 08:40 PM
VikingDiesel
Jul 9, 2006 02:10 PM
quantrill88
Feb 20, 2004 10:43 AM
quantrill88
Jan 14, 2004 02:30 AM
