Which injectors for my setup?
Old Nov 16, 2005 | 12:39 PM
Tiger Rag's Avatar
I'm looking into new injectors, currently I'm running stock injectors. As far as other mods go, I have an Edge Comp tapped, 4" exhaust, gauges, and a true flow foam filter for the stock air box. The truck is an 01.5 with a 6 speed and 4.10 rear end. One of my buddies here in town is about to switch out his Bosch RV 275 injectors to something bigger and I was thinking his old injectors would be pretty decent with the Comp and stock turbo. I can get a decent deal on the injectors. What do you guys think? Anybody running something similar? Will I be sorry I didn't cough up a couple extra $ and buy bigger injectors while I'm changing them out or should I do this for now, then upgrade turbo and injectors again down the road?
Thanks for the help, Matt
Old Nov 16, 2005 | 12:45 PM
strokethis600's Avatar
I would just get his old injectors for now. when you are ready to upgrade your turbo i would get bigger injectors. I think you would be putting to much fuel with bigger than 275s with your stock turbo.
Old Nov 16, 2005 | 01:22 PM
Big Deezul's Avatar
I run the RV275's with an EZ and its an awesome combo...I am sure it would be even nicer with a comp
Old Nov 16, 2005 | 01:35 PM
CTD NUT's Avatar
You can run up to a 100 hp injector with the Comp with the stock 12cm HX35 - you just have to be smart about it......WOT at 5x5 will be a bit toasty but it won't be anything you can't manage.......if you haul heavy, just turn the Comp off. Don't get me wrong, 100 hp stix and the Comp on kill will benefit from a higher flowing turbo for absolute max hp and egt control but it can be done with the HX35 until you do some turbo mods. I like the RV275's and they are a great combo with the Comp but the RV275's will eventually leave you wanting more. If you can pick up the used 275's for around a $100, I would say go for it......just don't expect them to be the last injector you will buy!
Old Nov 16, 2005 | 02:06 PM
Tiger Rag's Avatar
rv275's will be about twice that. $200 or so and less than a year old.
Old Nov 16, 2005 | 02:45 PM
CTD NUT's Avatar
That really isn't that great of a deal considering you can get new 275's for $280......it isn't really a bad deal either - it's just not "smokin' " deal either!
Old Nov 16, 2005 | 02:57 PM
Tiger Rag's Avatar
For $280, do you have to send your injectors in for core deposit? I won't have to trade him my injectors for cores. Not to mention, I get his help swapping them out since he has done it before and will have done it a second time before helping with mine. Probably a pretty fair deal on my end considering his expertise and help.
Bradleysram
19
May 12, 2009 08:36 AM
ryanihf250
Jan 17, 2008 02:58 PM
1882
Aug 26, 2006 11:50 PM
Trickflow
Jun 22, 2006 11:29 PM
VikingDiesel
35
Mar 20, 2006 07:06 AM
